Car dosent go into gear
Old Oct 17, 2006 | 05:35 PM
GonSpeed's Avatar
Originally Posted by chilibowl
n first gear, the front planetary gear is engaged, locking onto the input shaft. Think of this as the low gear on your bicycle. The gear ratio here is 2.46:1. This gets the car moving.
"Once the car is rolling, the transmission shifts into second. The intermediate band is applied, holding stationary the high clutch drum, the reverse clutch, and the sun gear. The forward clutch is applied, locking the input shaft to the ring gear. The gear ratio here is 1.46:1."
In high gear, the ratio goes to 1:1. All planetary gear members are locked to each other and to the output shaft.
"In reverse mode, the reverse and high clutch is applied. The input shaft is locked to the reverse and high clutch drum, the input shell, and the sun gear. Gear ratio for reverse is 2.17:1."
These are the basic workings or a Simpson transmission.
Oh yes, there are no clutches of ANY sort in an Automatic Transmission.
Im done debating with you.
i didnt say there wernt ANY clutches in it, there is no main clutch to connect from the engine. His problem would not be any of those clutches. There was nothing wrong i said in the previous post.
Old Oct 17, 2006 | 05:39 PM
chilibowl's Avatar
Originally Posted by GonSpeed
nah, put some tranny oil in it and it should roll. There is no clutch in an automatic
Damn I must be going crazy I guess.
Old Oct 17, 2006 | 05:43 PM
GonSpeed's Avatar
in a previous post when someone said it might be a burnt clutch, hope its a burnt clutch. He meant the main clutch everyone thinks of when you talk about a clutch for a car. You cant change a clutch inside a transmission unless your rebuilding the trans, which infiniti would probably just replace it.
arora_g35
Apr 16, 2026 02:52 PM
Blakearold
Aug 19, 2015 10:20 AM
DRG35R
Jul 31, 2015 10:23 AM
tehmoonrulz
Jul 19, 2015 10:44 PM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
