Compustar Alarm System Good?...
Old Oct 23, 2006 | 02:15 AM
MastaRip's Avatar
Compustar Alarm vs Viper 791XV
I got a 06 6MT Coupe and was wondering if a Compstar alarm,
http://cgi.ebay.com/COMPUSTAR-2W900FM-AS-CAR-ALARM-REMOTE-START-2-WAY_W0QQitemZ110046109573QQihZ001QQcategoryZ94832QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
is better then a Viper 791xv 2 Alarm
http://cgi.ebay.com/Viper-791-XV-2-way-Car-Alarm-Remote-Start-System_W0QQcmdZViewItemQQcategoryZ94832QQihZ003QQitemZ130038399498QQrdZ1QQsspagenameZWDVW
my main concern is which one is better for security and manual transmission
Old Oct 23, 2006 | 02:38 AM
IP G's Avatar
i would go with the compustar.
Old Oct 23, 2006 | 08:53 AM
MastaRip's Avatar
yea does any1 on the forum have a compustar that can tell me about it?
Old Oct 23, 2006 | 09:34 AM
Calvin's Avatar
Overglorified Altima
https://g35driver.com/forums/showthr...ight=compustar
Old Oct 23, 2006 | 09:38 AM
giddyup69's Avatar
i had a compustar on my former vette. it is the only alarm that i've ever owned that never seemed to output any false triggers. i was very satisfied by it. only thing i noticed was that the handheld unit showed some real wear and tear after just a year. i found the compustar better than the viper and clifford alarms i had previously.
Old Oct 23, 2006 | 11:20 AM
nyclifeg's Avatar
I had a compustar installed in my GF 05 6mt and it works great. What kind of questions do yuo have maybe I can try to help.
Old Oct 23, 2006 | 11:49 AM
MastaRip's Avatar
Thanks for the help,
I was wondering if its wise to get the remote start, dont they disable the clutch having to be pressed to start the car, also is it safe to remote start the engine all the time?
Old Oct 23, 2006 | 12:00 PM
Calvin's Avatar
https://g35driver.com/forums/showthr...r+remote+start
as long as you get a good one then remote starting will not hurt your car
Old Oct 23, 2006 | 02:21 PM
nyclifeg's Avatar
Basicaly when you come to a stop you have put the car in nuetral and let go of all pedals. Pull up the hand brake you will hear a click stating that manual mode has been activated. Then remove the key and exit the car. The car will run until you close the door. Once the door is closed the car turns off by it self and arms the alarm. If you dont follow this the alarm will not let you start the car.
Old Oct 23, 2006 | 02:27 PM
Hoozel's Avatar
I could be wrong here, but i think you will void the waranty of the Viper if you install it in a manual Transmission vehicle. As far as i knew Viper did not do Manuals at all. So that leaves you with Compustar, equally as good and maybe better in some areas.
Jusseth
Sep 13, 2020 12:25 PM
hdmark
Apr 29, 2019 04:31 PM
JMSABO
Aug 4, 2015 11:58 AM
gabe3d
Audio/Video/Electronics
Jul 19, 2015 05:43 PM
