Anyone have A DIY for changing brake pads?
Old Oct 25, 2006 | 12:04 PM
madchef's Avatar
Do you have brembo's?
https://g35driver.com/forums/florida-g-club/92495-my-brembo-pad-replacement.html
Old Oct 25, 2006 | 12:11 PM
Calvin's Avatar
Overglorified Altima
https://g35driver.com/forums/brakes-suspension-diy/52272-diy-5at-brakes-rotors-diy-oh-my.html
Old Oct 25, 2006 | 01:54 PM
madscientist's Avatar
that's funny, i was just about to ask this myself.
I was also wondering if there's a DIY for changing brake lines, or is this better left to a mechanic?
Old Oct 25, 2006 | 04:04 PM
Soopa G's Avatar
easy, as long as you know how to bleed then properly
Old Oct 25, 2006 | 04:46 PM
sliderg35's Avatar
StopTech has an excellent writeup on bleeding brakes. With 2 people,it's a piece of cake!
http://www.stoptech.com/tech_info/wp...edbrakes.shtmlI put in Stoptech Stainless Steel brake lines myself. It's real easy.
Old Oct 26, 2006 | 03:56 AM
very cool. looks like it's PROJECT TIME!!!!
Old Oct 26, 2006 | 09:29 AM
BroDaJin's Avatar
I think you should let safety related items for the pros. I have seen alot of guys trying to do brake work by themselves causing more harm then good. Just be carefull people, always use the right tool for the right job. DO NOT BLEED THE SYSTEM when your just replacing the pads.(some people actually do) Only time you bleed the system is when theres brake fluid involved in the work. Always double check and test drive after you service the brake. I dont care if you die but watch out for the other people around u =P
wuppiedog
Aug 7, 2015 11:16 AM
kinetek
Aug 3, 2015 04:25 PM
sahizzle110
Jul 29, 2015 11:36 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
emorehs
Jul 17, 2015 09:45 AM
