Gas door won't open
Old Oct 25, 2006 | 09:31 PM
focker's Avatar
Gas door won't open
Hmm all my doors are unlocked, I push the thing and it won't open. It's an 04 g35 coupe.. i called inifiniti, they're retards. Is there a lever or something that i can pull to open it? Thanks for the help
Old Oct 25, 2006 | 09:41 PM
Triji's Avatar
Hmmmm, DId you re-lock and unlock the doors? Try to open it with the engine running? Is there a button in the glove box like for the trunk? Never had that happen to me...
I'll see what I can find when I get a chance to get to my car..
Old Oct 25, 2006 | 09:43 PM
Silver350GT's Avatar
It just a push pin that pops it out and I think a small magnet that holds it in place....
Old Oct 25, 2006 | 09:46 PM
focker's Avatar
Yea.. i've unlocked and locked the doors, turned the car on.. left a door open, popped the trunk.. pretty much everything lol. I can't open it, and i really dont feel like prying it open in case i break something. bleh.. luckily the gas station is 30 seconds from my house or i would have been screwed..
Old Oct 25, 2006 | 09:50 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
there was a thread about this a while back. I'm pretty sure that if you pop the trunk and pull back the lining, there's a button or something that you can use to manually release the latch to open the gas door.
-GP-
Old Oct 25, 2006 | 09:54 PM
focker's Avatar
Ahh i figured it out guys, i stuck a credit card in there and opened it. I guess the spring was bent and it wouldn't release. THanks for the help guys, appreciate it
Old Oct 25, 2006 | 10:24 PM
GreenGoblin's Avatar
The goblin resurrection
glad that you got it fixed up
Old Oct 26, 2006 | 01:41 AM
MUSCARLIVE's Avatar
The same thing happened to me on my 03' coupe. In my case it was a little
spring mechanism that is i a little rubber boot that that pops the door open was broke.
Old Oct 26, 2006 | 12:13 PM
neo_rambo's Avatar
That happened to me two weeks ago. Dealer will replace it under warranty don't break anything. look to see if you see my post about it. Look inside the trunk, take off the right side carpet molding. get a ice pick and remove all the push pins in the area two for the trunk cargo net hooks and 3-4 for the carpet molding. After you remove it you will see a white actuator lock there is a small **** or button on the right of it push or pull it gently and it will unlock the door. Mine failed cause after that It would NOT lock Dealer replaced it no probs just don't break the lock cause they won't replace it.
Old May 29, 2012 | 02:31 AM
bighapa's Avatar
If this happens to you guys again, just stick a credit card in the gap. It worked for me and haven't had a problem with it again.
Old Sep 8, 2013 | 12:09 AM
blAk mAx's Avatar
happened to me. pulled back the trunk liner and pulled the relase. Top ****
Old Sep 8, 2013 | 05:56 AM
Blue Dream's Avatar
I drove ttrank's car solo
hahahahahahahahahahahahaha
Love your sig, Ichiba FTMFGDF.
Old Sep 8, 2013 | 02:43 PM
gary c's Avatar
Love these ancient threads that we're still receiving responses for 6 years later, and they include pic!
Gary
Old Sep 8, 2013 | 03:27 PM
blAk mAx's Avatar
When it happened I googled and this thread came up first. I wanted to add a pic for the next person who googles g35 gas won't open
