Someone help me find that thread.
Old Nov 9, 2006 | 01:09 PM
nchima's Avatar
Searched for an hour.
The thread on radar detector hardwiring with a bunch of pics and whatnot.
Thanks.
Old Nov 9, 2006 | 01:24 PM
nchima's Avatar
bump
Old Nov 9, 2006 | 02:55 PM
izmir41500's Avatar
G35driver Addict
Old Nov 9, 2006 | 11:37 PM
nchima's Avatar
Nope.
Not any of those.
It's the one were all the members posted up what they had in it.
Still been searchin for a couple of hours now.
Old Nov 10, 2006 | 12:14 AM
nchima's Avatar
Please help
Old Nov 10, 2006 | 12:22 AM
filanj's Avatar
which unit are you hardwiring? ... regardless it is very simple..
my unit sits to the right of my rear view mirror. I tucked the wire up into the seam along the windshield and rain it down the drivers side A pillar. When I got to the dash, i continued down the trim in the seal to the compartment under the steering column and above the pedals. I used the fuse box on the back right corner of the left wall. It's the accessories fuse box. I have a concealed display that runs up through the steering column to my gauge cluster. The connector for the valentine hardwire kit ( i think it's called a J11 splitter) is spliced and plugged into either the dome lighting or the homelink so that it only powers up when I turn the car on. The fuse is 10v, if I remember correctly, so it is more than enough to handle the extra power
Old Nov 10, 2006 | 12:30 AM
nchima's Avatar
I'm wondering how you run the wire from the rear view mirror.
Pillar A?
Need like pics.
Old Nov 10, 2006 | 12:33 AM
filanj's Avatar
I'll take some pix tmrw... i'll refer you to one of my links with some pix...
https://g35driver.com/forums/audio-video-electronics/122220-my-custom-valentine-1-concealed-display-w-pix.html
Old Nov 10, 2006 | 12:35 AM
filanj's Avatar
the A pillar is the pillar between your windshield and drivers side window
Old Nov 10, 2006 | 12:36 AM
filanj's Avatar
(the A pillar is also on the passenger side as well)... but i ran it down the drivers side A pillar
Old Nov 10, 2006 | 12:50 AM
nchima's Avatar
Thanks, Yea if you could provide me with those pics on better detail, I would appreciate it.
Old Nov 10, 2006 | 01:48 AM
X 350GT X's Avatar
check this out...
http://en.wikipedia.org/wiki/A-pillar
Old Nov 10, 2006 | 02:51 PM
filanj's Avatar
I pulled the wire out in some places so you can see where it runs... it is very easy to push the wire behind the headliner and pillars. Once you get to the bottom of the A pillar, run the wire along the edge, as shown, to the rubber runner that goes down the opening of the door frame and pop off the underbelly of the steering column if you have a concealed display as well to hookup the J11 connector... the next post will have where you should plug into... which is actually a 15v fuse...
Old Nov 10, 2006 | 02:53 PM
filanj's Avatar
sorry for the crap resolution... from my phone...
the fuse box is next to the dead pedal
Old Nov 10, 2006 | 03:49 PM
nchima's Avatar
Thanks for the step by step pics.
Last question is were you ran the wire from the last pic.
On a side note, everywere you ran the wire did you have to pull out the components in the car or whatnot. Or did you just squeeze the wires in through the car.
