Quantum tint - GPS - Siruis
Old Nov 18, 2006 | 03:54 PM
ilyaat's Avatar
Coupe
Quick quetions. I heard that Quantum tint is not so good for GPS...but don't 04 couples have GPS antena in front? So that shouldnt effect it, right? But what about Sirius radio - I have antenna installed on back of the roof, near rear window. WIll taht effect the signal? (don't really care since subscription will be running out at the end of the year and not gonna renew..but since i still have month+ of service, would like to hear an answer)
Thanks
Old Nov 18, 2006 | 04:58 PM
GreenGoblin's Avatar
The goblin resurrection
I have never heard that but not sure
Old Nov 18, 2006 | 07:11 PM
DrewTheSuit's Avatar
from what i've heard if you get a metallic base tint you may have trouble with GPS/navi IF your antenna is outside the car, but with most aftermarket navi setups your antenna is inside so it will not make a difference. ceramic tint is a good alternative if you have stock navi. i've never heard of quantum tint, but i hope the above mentioned helps.
Old Nov 19, 2006 | 04:44 PM
ilyaat's Avatar
Coupe
bump. any ohter comments/ I called local Infiniti todya, and they A: dont know where the GPS antenna is located on the coupes B: they say, sicne I have sirius radio, GPS reciever is in the same antenna (aka that little Sirius unit on my roof)
Old Nov 19, 2006 | 04:47 PM
(>")> G35's Avatar
Only problem with metallic based tint is if the gps antenna is in the interior rear deck because you'll tint rear windows and block some of the signal. From what I heard on the g it's in the front. Anyways I have a metallic based tint,my radio and navi work fine.
Old Nov 19, 2006 | 04:52 PM
if your antenna is on your roof i'd go with ceramic just to be on the safe side, you could try the same question in audio forum, someone with sirius is bound to have tinted their windows
Old Nov 19, 2006 | 05:21 PM
Drtybrd61's Avatar
I got a metallic tint and have not experienced any problems with my GPS. The metallic tint, however, does seems to have a subtle effect on radio reception, more so AM than FM.
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
R350k5
Lights
Jan 12, 2016 09:22 AM
Tmatheso
Dec 13, 2015 03:24 PM
NailBomb
Oct 28, 2015 07:53 AM
