Glove box light visable?
Nov 23, 2006 | 06:42 PM
Anyone look over and see your glove box light on all the time? ANyone try to take it back to dealer to fix it? Thanks
Reply 0
Nov 23, 2006 | 06:53 PM
I thought i was going crazy myself.!! Yes i see it at night when i drive..Looks like a little crack inbetween thew dash and the glove box.!! Am i correct? ^^
Reply 0
Nov 23, 2006 | 06:54 PM
I noticed the same in mine...i thought it was just me....
Reply 0
Nov 23, 2006 | 06:56 PM
Ima take mine back when i finish this bull **** a$$ so called oil consumption test.!!
Reply 0
Nov 23, 2006 | 07:20 PM
Keep us posted what the dealer says..
Reply 0
Nov 23, 2006 | 08:19 PM
The light shines through the crack on mine also and it drives me crazy. I think that it's because the light isn't switched and the plastic door is crap. The major complaint I have about the G35C is the quality of the plastic in the interior.
Reply 0
yea i have that problem too....i never know why...im like damnit sooner or later thats going to kill the bat...keep us posted on what the dealer says about that.... i was goin to go in...but ive been lazy and havent enough time cuz of finals coming up
Reply 0
Nov 23, 2006 | 08:21 PM
not a problem with the light , always comes on with exteror lamps
get your g-box door adjusted.
Reply 0
Nov 23, 2006 | 08:27 PM
Quote: not a problem with the light , always comes on with exteror lamps
+1. that light comes on with all the other switched lights. No more glove box door switch.
Adjust the door yourselves. All Infiniti will do is twist the door (carefully) until it alignes properly.
C.
Reply 0
Nov 23, 2006 | 08:35 PM
Disable the bulb if it bothers u so much because there's no switch for it.
Reply 0
Nov 23, 2006 | 08:46 PM
I brought it bak to the dealership and they said they cant do anythin about it!!!!!!
Reply 0
Nov 23, 2006 | 08:53 PM
mine does it too and as for the same as 2006 g coupe ill let them fix it when they finish my oil consumption test
Reply 0
Nov 23, 2006 | 10:24 PM
I just noticed that tonite too!!! The top glove box light is also on if you look on the crack on the left side. So that means the light stays on all the time when the headlight is on... wouldn't that eventually drain the battery?
Reply 0
Nov 23, 2006 | 10:28 PM
I took it in for it, they just tried to bent it. Still visible.
I gave up and just try to ignore it.
Reply 0
Nov 23, 2006 | 10:35 PM
that light drives me crazy as well
Reply 0
