How to install the N1 Front Lip?
Old Dec 6, 2006 | 06:50 PM
Jining's Avatar
Hello, I know some people on the forum have the N1 Front lip. I recieved mine today, and it came with a bag with 2 brackets and a bunch of assorted screws and washers, but no instructions of any sort. Just curious if someone could help me out, thanks a lot!
Old Dec 6, 2006 | 07:55 PM
clifftrail's Avatar
Pretty straight forward. Put the lip on, put two screws in each end. Look underneath and you will see that the brackets attach to the center points and also attach to the bottom wind deflector. I think there may be one more location on each bottom side on the ends also. Trying to go off memory here, just follow the holes. GL.
Old Dec 6, 2006 | 08:03 PM
Jining's Avatar
Hmm, so did you use any sort of double sided tape at all, or just the 2 brackets? I notice there is a lot of washers and different size screws, am I to use them all somehow?
Old Dec 6, 2006 | 08:06 PM
reggiek's Avatar
I didn't think it was strong enough to handle bumps, shakes and the ocassional bump against a curb so I took it to a bodyshop. They took one look and agreed it needed more support. In fact, I remember a couple os guys on the site saying theirs fell after install. My bodyshop guy drilled extra holes for support and used adhesive. It's on tight.
Old Dec 6, 2006 | 08:21 PM
Jining's Avatar
Hmm yea I was thinking maybe of taking it to a shop.. rough guess on how much they would charge? and anyone happen to know one near seattle area?
Old Dec 6, 2006 | 08:40 PM
clifftrail's Avatar
I put mine on with the hardware included. The lip is molded so tight that it almost stays on without hardware. It's very solid with the small amount they provide, but if you want more, then do it. I did not install any adhesives either. Matter or fact, a couple of weeks after I had it I pulled too close to a curb (be careful) and popped the two screws off that hold the metal brackets on the bottom of the deflector shield. The lip still stayed on the car just fine even with those two off until I got home and put them back.
I do alot of city driving with moderately rough roads, occasional 70-80 on the freeway for a brief period, so if you are going to subject it to more wind force than what mine sees, you may want to follow reg's advice.
Anyway, GL with your install, it will look good on the car.
Old Dec 6, 2006 | 09:02 PM
reggiek's Avatar
I can't speak for the Seattle area bit I paid $200 for paint and install. Not bad in my opinion.
Old Dec 6, 2006 | 11:53 PM
GreenGoblin's Avatar
The goblin resurrection
that is not that bad 200 painted and installed
Old Dec 7, 2006 | 01:09 AM
nchima's Avatar
Just do it slow and steady.
Old Dec 7, 2006 | 07:24 AM
Jining's Avatar
So do I need to do any drilling at all? What did you mean by "put two screws in each end." I am only using those 2 brackets to hold the bumper on correct? Sorry for so many questions, I appreciate the help.
Old Dec 7, 2006 | 07:25 AM
Jining's Avatar
Are there holes already pre-drilled into the lip? (sorry the bumper isnt with me and I cant remember)
Old Dec 7, 2006 | 08:33 AM
BigShow's Avatar
i advise to make sure 100% that its on there good! my body shop charged me $100 for paint and install and literally 5 minutes after driving out the screws on the bottom got loose and the lip dropped to the floor while i was driving and i ran over it
Old Dec 7, 2006 | 11:00 AM
where did you go ^
Old Dec 7, 2006 | 05:27 PM
Jining's Avatar
Hmm so... I now see the lip has holes, but the bracket doesnt seem to line up with any of the bolts under the front bumper....please help.
Old Dec 7, 2006 | 05:31 PM
Jining's Avatar
oh and also, do the sides not fit flush with the wheel well? My lip sides are slightly bent when I test fit it... if you understand what im saying.
