Tire Wear ????
Old Dec 28, 2006 | 03:08 PM
OU812G350's Avatar
Tire Wear ????
how long do front tires last on g-coupes??? i have 17" and the fronts insides are about gone at 16k miles...the service dept told me all g coupe wear the fronts out its the way the front end is designed....if this is tru the 17s are staying on and the 19s will have to wait........
Old Dec 28, 2006 | 03:55 PM
cochinogato's Avatar
i'm not sure about the front's, but i recently had to change my rear tires- I had screws in my front AND rear tire and one of the guys at the tire shop wouldn't repair the rear tire because the thread debt was beyond 3/32 - He told me the front's last longer but then again He also told me that our Bridgestone Potenzas have a short life span- I have an '05 (got it in June) 19s and changed my rear tires first week of Dec.
Old Dec 28, 2006 | 04:01 PM
OU812G350's Avatar
YEA ...with a tread rating of 140 and super hot temps and spirited driving i cant imagine the b-stones lasting long on the rear.......
Old Dec 28, 2006 | 05:28 PM
SilverII's Avatar
my oem 17 front is still good....around 20K and about 1/4 left...however, my rears are gone at 11K.
Old Dec 28, 2006 | 07:34 PM
reggiek's Avatar
Have you done an alignment? Tires burning up at 16K miles is not unreasonable but you should get more out of them with proper air pressure and alighnments. I usually take mine in twice a year...more if I have been driving hard a lot.
Old Dec 28, 2006 | 07:36 PM
EX-250's Avatar
My pilot sports last 18-22k miles in the arizona heat.... 16k on the fronts sounds like you had some fun with the car around turns or ramps. I'd be a little concearned as I replaced the set when the rears go bad all at the same time, the fronts usually still have a good amount of tread left.
Old Dec 29, 2006 | 01:03 PM
OU812G350's Avatar
alighnment done at 9k after wife hit something.they replace rf tire/rrtire and rim.. rechecked alighnment yestarday. told me caster or camber is out 1/8 of a degree..but not to worry it not enough to mater???? wife drives daily and shes no racer except on the highway 100+......tire pressure always max 30psi min 28psi.......{h e l p }
Old Dec 29, 2006 | 01:09 PM
blueSKYLINE's Avatar
i had 18s before with michelin pilot tires and both front and rear lasted till 33K ... even though my dealership told me to change them when i had 20K on the car, i just didn't listen because i could see i had plenty of thread left
also check this thread:
https://g35driver.com/forums/g35-coupe-v35-2003-07/92325-how-long-did-your-original-tires-last.html
Old Dec 29, 2006 | 03:19 PM
OU812G350's Avatar
yo...blueSKYLINE thanks for the link...looks like 17s should go at least 25 k before needing replacement....i'll take the g to some one other than infi.to double check the front end.........
Old Dec 31, 2006 | 05:39 PM
reggiek's Avatar
There's the problem right there. That's not enough air. I run 38 psi front and 36 rear. I believe you can go as high as 44 on Michelin Pilots but the ride is too harsh. 30 is terribly under inflated. If you don't believe me, call a high end wheel shop. Dealerships and regular places like Pep Boys or Sears know nothing about performance tire use. I have over 20 years experience.
Old Jan 5, 2007 | 02:29 PM
OU812G350's Avatar
If u look on the door it states 30psi ....and even at 30psi it rides rougher than i would think........
Old Jan 5, 2007 | 02:39 PM
inspector_yoo's Avatar
When I replaced my old 17's, my rear's were completely gone but my front's still had thread on them. This was around 25k I think. My rear tires were really, really gone though.
Recently, I just changed my rear brake pads. My front's still had room on them. Lol. Too many brakestands I guess.
Old Jan 5, 2007 | 06:01 PM
reggiek's Avatar
That's for the stock tires. Do you still have stock tires? My advice is only for PS2's. Use the tire manufacturers recommendation and you'll have longer tire wear. The Michelins on my Lexus have been there for 3 years. 38 front 36 rear. I do need a rear drive tire...the one that does the most pushing but the other 3 have more life in them.
Old Jan 12, 2007 | 11:03 PM
OU812G350's Avatar
yea there oe goodyear RSA 225 front / 235 rear...im either going to go to 18'' factory sport rims or go up 1 size wider front and rear with a sumitomo or nitto tire...
Old Jan 12, 2007 | 11:18 PM
gary c's Avatar
Sounds like Bridgestones...............
Your lucky I only got 10K miles out of my last set of Stones. For what they
cost that is damn poor. On the sidewall of all tires is information on how
long the tred will last. Bridgestones are normally 140. Don't buy tires that
have less that 220 or 240! Get your 19s but deal with a company like the
TireRack and tell them you want quality tires that have a tred wear of at
least 240...traction AA etc. Michelins or Goodyears with the tread wear
of 220 or better will last you 30K......unless my wife is driving!
Check inside your door for the correct tire pressure 30 lbs isn't enough.
I run 37 lbs on all four corners without any issues.
