Battery
Old Dec 31, 2006 | 05:00 PM
WhiteonWheat's Avatar
^ So anyone know the advantages of purchasing the expensive Optima?????
Old Dec 31, 2006 | 05:05 PM
JDM 350GT's Avatar
8000 miles and it's been 1 year and 8 months +
not a single problem, yet.
Old Dec 31, 2006 | 06:19 PM
GEE PASTA's Avatar
Florida G35 Club
Optima D-35 (Yellow top) is a great replacement. It holds great voltage up to , and over 14 volts.
Its weight is lighter than OEM . I noticed that my 6 month old OEM would not hold over 12.2 volts after sitting more than 2 hours. Understand that alternators run at 14.2 volts output or higher to charge.
Why have the alternator always under a load to charge a battery that will not hold 12.2 volts.
Spend the money, and be real happy. I believe there is a R-51 Optima that may be offered now.
R= Reverse terminals,,,,,,,,, I swear that my car responds better to the extra voltage.
There is a write up on this, on this forum.
PS Throw on some Grounding Gear, Ground wires and be set.
Old Dec 31, 2006 | 06:44 PM
g35pat's Avatar
3 years and 8 months on my G35 with the original battery. No problem to report.
Old Dec 31, 2006 | 08:43 PM
Pauliejr's Avatar
Stinger!!! Mabe Be A Few Hundred Dollar ( Some Where From 375-400) But Theere The Best
Old Jan 1, 2007 | 12:23 AM
silvsurf's Avatar
4 years next month...no problems.
Old Jan 1, 2007 | 04:05 AM
Combilation's Avatar
Thats funny I bought my car used at a somewhat major delarship and I test drove it and everything. I took the car home and all the lights went out and the battery died. I couldnt turn the car off or else I had too jump. So yeah that sucked.
Old Jan 1, 2007 | 12:15 PM
V35 Skyline GT's Avatar
6MT Coupe
Our batteries should last around 48-72 months. Not sure what Nissan gave us, but what's nice about ours is you can easily check the cell levels and add distilled H20 if necessary, unlike most sealed batteries that are a pita to check and most ppl think they can't check/service those kind.
Look on the front side of battery and you'll see an upper level line and a lower level line for your cells. Add if below lower level line.
My 06 batterry is like this, don't know about earlier years.
Old Jan 1, 2007 | 01:35 PM
audio_file's Avatar
Love my red top, but I think i got the wrong one, I had to mount the battery face down to get the leads to reach the posts (the posts were opposite from my original) Car starts effortlessly, seems more instantly responsive, and you save some weight (down from 3400lbs to 3399 : ) )
Old Jan 2, 2007 | 07:09 PM
culi's Avatar
Thanks for all the replies. I'll check my battery fluid level.
Happy new year to all!
Old Jan 2, 2007 | 07:23 PM
FenixL1P's Avatar
my previous 2k2 6spd maxima that i bought in jan 02 is still on it's original battery after 80,000 miles (currently owned by my brother and the car haven't given a pipsqueek of a prob for him yet... knock on wood).... i didn't leave the headlights to go off automatically very often.... been doing the same with the g so hopefully it will last just as long.
Old Jan 31, 2007 | 11:32 AM
Eticketride's Avatar
OK, my OEM battery is going on 4 yrs 5months or so...It has been a little slow in starting lately. When I turn the key, it hesitates for about a second then turns over and starts. Today, it had a lot of trouble just trying to turn over. I'm guessing it is the battery, but I guess I would need one ASAP. I haven't checked the water level in the battery, because I thought it was a sealed batter. I will check today.
Gee Pasta - I know this is the coupe section, but is it the same battery for a sedan? I have a sedan and have seen all the posts about the optima batteries. I'm just looking for a replacement, no mods and no improved audio system. Is the D-35 yellow top or R-51 a direct fit? Do I need that spacer or riser that some people talk about? And are the terminals in the right orientation? I know these questions have been answered before but any clarification would be much appreciated...Any place local to get one of these optima batteries??? Last time I checked Costco, they had some, but I'm not sure what size they had...Thanks!
KruZZe
Feb 27, 2023 05:04 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Thebaws11
Nov 30, 2016 12:54 PM
g.spot
May 9, 2016 10:54 PM
dcsbh1
Oct 1, 2015 03:15 PM
