fuse location??
Old Dec 30, 2006 | 10:49 AM
strcdan's Avatar
fuse location??
hey guys i just picked a a g35 the other day and im wondering if anyone knows where the fuse is for the gauge cluster?
Old Dec 30, 2006 | 08:54 PM
strcdan's Avatar
nothing huh?
Old Dec 30, 2006 | 09:10 PM
a13xkim's Avatar
there are 3 fuse box locations... one is on the left side next to the pedals(if u have a manual u have to remove the dead pedal to get to it) second is under the hood under the batter cover, just pop it off and you should see it, and the third is behind the battery which u have to pull up. Just reach back there and lift up what looks to be a black box but is really a lid. oh and use the search cause sometimes you will find the answer faster than someone will reply. plus u wont get flammed
Old Dec 30, 2006 | 09:11 PM
kennyz424's Avatar
Try the fuse box under the hood or the emergency box which i believe is under the driverside area to the right. or it may be the passenger side... you need to remove the paneling.
kennyz424's Avatar
forget it lol the guy above me pretty much made me fee like an idiot with post lol at least i tried !
Old Dec 30, 2006 | 09:24 PM
strcdan's Avatar
thanks i guess i have to just pull one at a time to find it! I did a search and came up with nothing. Im familar with forums
Old Dec 30, 2006 | 09:27 PM
a13xkim's Avatar
haha nah its just cause ive blown one too many fuses on my G doing some eletrical stuff. one time i burnt the ignition fuse which is a different fuse that you would most likely need to order from the dealer and they will charge you an arm and a leg. Had to soder that bad boy back together or i was gonna be stuck in the radio shack parking lot forever!!
Old Dec 30, 2006 | 09:28 PM
a13xkim's Avatar
yea im still trying to use the search more efficiently. hope you find that fuse your looking for
Old Dec 30, 2006 | 09:37 PM
kennyz424's Avatar
lol one time i blew a fuse that wouldnt allow my car to start so i thought it was my fuel pump... i took off my exhaust and intake and made it stock again and took out my system because the stealership is an *** when it comes down to warranties...turns out it was a blown fuse not the fuel pump and they charged me $120 to fix A FUSE because they saw my wiring for my system lolol
Old Dec 30, 2006 | 09:46 PM
strcdan's Avatar
well im just seeing if anyone has found the one fuse for our cluster
Old Dec 30, 2006 | 10:11 PM
kennyz424's Avatar
try the car manual ... it should be in that if im not mistaken
Old Dec 31, 2006 | 04:49 PM
strcdan's Avatar
yeah i looked in there and it tells me nothing! like all my other cars it tells u wich one is wich, but not infiniti of course
Old Jan 6, 2007 | 06:04 PM
TheForgottenMan's Avatar
The dash board on the right (glove compartment light) blown out in my car. Which fuse will that be? The driver side fuse, battery side, behind battery? I don't want to go through all the trouble. Does anyone know?
Oh, and its not the light bulb. I replaced it already and it still doesn't work. So I am guessing its the fuse. So can anyone tell me which fuse it is and where?
Old Jan 6, 2007 | 07:44 PM
Mr.GEE's Avatar
20 Year Member
The glove box light will only work when the lights are on. I thought my bulb was burned out at first, then I thought it may have been the switch, tore up the dash trying to find the problem and then come to find out that the light worked fine when the lights were on. I felt like an idiot after going thru all that, thinking there was a problem. As far as finding the fuse, you should look in the back of the fuse compartment cover. The list leaves alot to be desired as far as fuse description goes so good luck. There was a thread in "G35FRENZY.COM" Where someone had posted an entire service manual for 2004 G35 coupe. You may want to do a search over there to see if you can find anything like wiring diagrams that show fuse numbers and location.
Old Jan 6, 2007 | 10:10 PM
Cool thanks alot man!!
G35-R
Nov 7, 2015 01:21 PM
ZoominG35
19 Inch
16
Oct 30, 2015 05:44 PM
ZoominG35
Audio/Video/Electronics
Oct 12, 2015 04:53 PM
2014g35x
Sep 11, 2015 07:53 PM
pasjr1972
Sep 1, 2015 10:17 PM
