huge problem with rear speakers!!!
Old Jan 9, 2007 | 12:17 AM
PEARL-G's Avatar
Trying to install my focal 165k2p's into the rear side panels of my car when to my extreme dismay there is absolutely zero clearance!! removing more paneling i see that i can cut the back of the speaker pod out, but another huge freggin problem, there is a structural brace going up each side of the car!!would you reccommend taking like a 4" notch out of that brace or would it cause a structural weak point? Please i need expert advice here!!!! i cant put these speakers in the rear deck cause ther rear deck grilles are only cut out for 6 1/2's i would have no room to install a tweeter, please dont tell me i just wasted a $1,000 on a pair of speakers that wont f*%kin fit.
Old Jan 9, 2007 | 12:59 AM
Meatshackle's Avatar
Deep Sea Moderator
You might want to check out the AUDIO section. Are you using spacers?
Old Jan 9, 2007 | 01:17 AM
PEARL-G's Avatar
yeah i would have to except that the speaker hits the panel with the spacers.
Old Jan 9, 2007 | 10:07 AM
wilksoner's Avatar
oh **** i just ordered these for the front doors are u tellin me they wont fit in the front too? where did u pay 1000 i paid 380 at woofersetc.com
Old Jan 9, 2007 | 11:29 AM
GreenGoblin's Avatar
The goblin resurrection
that sucks lets up know what happens
Old Jan 9, 2007 | 12:46 PM
Deep Sea Moderator
I was able to mount my XR650s in the rear with spacers, 3 layers of dynamat, and some "re-positioning" of inner sheet metal. Anything is possible.
Old Jan 9, 2007 | 06:45 PM
PEARL-G's Avatar
xr650's are not as deep as the focals. with the speaker's magnet being stuck to the sheet metal behind the 6 1/2 plate, the plastic panel hits the speaker. If i were to use a spacer it would have to be like 3" thick. do you have any pictures?
i already hav e the k2p's installed in the front doors.
Old Jan 9, 2007 | 08:09 PM
Deep Sea Moderator
Wow. Those are pretty deep then. If you want them back there that bad you'll probably have to modify the 6x9 holes and mount them there.
Old Jan 9, 2007 | 08:16 PM
aorbeta's Avatar
Scosche SA69 6x9" to 6.5" adapter. Even has a spot for a tweeter. Never used them before but worth a try at $10.
http://cgi.ebay.com/Scosche-SA69-6x9-to-5-25-and-6-5-speaker-adapters_W0QQitemZ230044104721QQcmdZViewItem
mjfenix
Aug 17, 2017 05:49 AM
atk08
Jul 30, 2015 03:12 PM
Soumilg
Jul 18, 2015 12:33 PM
EasySausage
Jul 14, 2015 11:17 PM
