Stillen CAB/Ztube
Old Jan 20, 2007 | 09:50 PM
dcityjatt's Avatar
Stillen CAB/Ztube
Hi guys,
I ordered the following from the stillen website
http://www.stillen.com/product.asp?i...E01&c=PE&m=all
Upon receipt, I took the car over my buddy's to do the install, only to find that the z-tube is too short? Did anybody else buy the same exact pkg? if so, how did u manage to install the ztube? What other additional stuff do i need to get it installed and where do i purchase it?
Thank you for your help!!
Old Jan 20, 2007 | 09:59 PM
castertroy101's Avatar
http://www.stillen.com/product_files/403235~inst.pdf
Found that on the site link you provided under the notes section. I think that should fix your problem as to why its short. Good luck
Old Jan 20, 2007 | 10:23 PM
dcityjatt's Avatar
Favor
Is it possible for somebody to copy the contents of the pdf file and dump it in a .doc (word) file? I am at my bro-in-laws and dont wanna install adobe on here.
would really appreciate the help!
Old Jan 20, 2007 | 10:29 PM
Tjeh's Avatar
INSTALLATION INSTRUCTIONS
“Z” TUBE
INFINITI G35 / G35X / FX35
Installation:
1. Remove the stock intake tube.
2. The new intake will install with the PCV port on the bottom, pointing to the rear of the vehicle. Transfer the
rubber flex boot and the rubber elbow to the new intake tube. Do not tighten the clamps yet.
3. Install the new tube and connect the PCV hose to the bottom. A little spray lube will make the tube install
easier.
4. Twist the inlet tube until the tube, rubber elbow and throttle body are aligned.
5. Tighten all clamps.
6. Done.
Parts supplied.
1. Inlet tube
Tools required.
1. Screwdrivers
2. Pliers
3. Silicone spray lube. (optional)
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
hawaiian5
Sep 20, 2015 07:12 PM
