'06+ Passanger Headlight
Old Feb 2, 2007 | 12:51 PM
dan61177's Avatar
Looking for a Passanger side only '06+ G Coupe headlight. Mine shorted on my '04 G Coupe and I don't want to pay Infiniti pricing.
Old Feb 2, 2007 | 12:57 PM
redlude97's Avatar
replace the ballast or bulb instead of changing the entire headlight
Old Feb 2, 2007 | 01:17 PM
dan61177's Avatar
The bulb is good I need the ballast
Old Feb 2, 2007 | 01:30 PM
redlude97's Avatar
so why not buy a ballast rather than a whole headlight?
Old Feb 2, 2007 | 01:40 PM
dan61177's Avatar
Well thats what Im trying to do but it's still very Expensive
Old Feb 2, 2007 | 01:44 PM
Mike_Deezy's Avatar
How did it short out?
And not sure if this will work or not but if you can't find just the ballast alone it might be cheaper to buy a set of used 03-05 headlights and use their ballasts? I think the headlights are going for around $200-$250 with bulbs and ballasts.
Old Feb 2, 2007 | 01:47 PM
dan61177's Avatar
Ok I'm on the phone with Infiniti and they say the price they quoted me for is for the ballast/module.
Old Feb 2, 2007 | 01:49 PM
dan61177's Avatar
The ballast kept popping off of the headlight assembly and I kept popping it back on until one day it popped back on and te light never came on. I took it to Gunn Infiniti and they say its a bad module/ballast
Old Feb 2, 2007 | 01:54 PM
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
If you just need a ballast, I have a few extras. I can sell one for $75 shipped. Just the ballast, no wiring. But all these ballasts are 100% working.
Old Feb 2, 2007 | 02:15 PM
WILD121's Avatar
wouldnt be covered under warranty????? I would think about just upgrading to the 06 headlight assembly.
Check this thread out. Please Vote.
https://g35driver.com/forums/florida-g-club/137910-how-do-you-like-my-new-avatar.html
Old Feb 2, 2007 | 03:23 PM
dan61177's Avatar
https://g35driver.com/forums/showthread.php?t=137910
Um WHAT!?!?! I have upgraded to '06 headlights. Now 1 is bad and they will not warranty it because my car did not come with '06 headlight. It came with '04 headlights. They said the module and ballast are 1 peice. if that is what E_K is selling I'll but one but I do believe I need the whole Ballast and module. I'm getting my car back today and I'll pull it apart and see what I need for sure.
Old Feb 2, 2007 | 03:55 PM
E_K's Avatar
E_K
The HID system is comprised of the following components:
+/- wiring coming from the wiring harness going into the ballast, which then sends a separate wiring/bulb connector to the HID bulb.
Assuming that you have coupe, the ballast and ignitor is one unit (the gray octagonal unit). I don't know what you mean by "module."
Old Feb 2, 2007 | 04:12 PM
dan61177's Avatar
I'll pull it apart this weekend and look at what all I've got there.
Old Feb 2, 2007 | 04:20 PM
badtziscool's Avatar
Go to ebay and search for "nissan ballast". You'll find a whole bunch there for MUCH cheaper than dealer.
http://cgi.ebay.com/ebaymotors/Infin...spagenameZWDVW
I'm pretty sure that's the same ballast type that the G35 headlights uses, but you might want to take yours out and get a visual just to make sure.
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
