Air leak, window seal
Old Jul 25, 2011 | 09:44 AM
  #31
ajm216's Avatar
I recently had my passenger door glass replaced, thieves broke it while breaking into my car Now at about 78-80mph I notices a whistling sound, I'm going to check the drives side and compare to the passenger side to see if the glass is seating correctly.
Old Jul 25, 2011 | 11:35 AM
  #32
R10T_x's Avatar
had the same issue a little while back i just replaced the seals cost me 50 bucks
Old Aug 28, 2011 | 09:07 PM
  #33
valetkyle's Avatar
Do you have the part numbers?
Old Oct 4, 2011 | 11:55 PM
  #34
Tek12x's Avatar
Hey Guys and Girls,
I had the same problem and what I did was reset the motor using the steps found online. Then once I was done with that I loosing (not remove) all the bolts for the window and with the window all the way up I had a friend pull up on the window to raise it up a little more then go back and tighten the bolts back up. Then put the cover back on. BAM!! no more window sound.
mattdg35
Sep 14, 2015 11:28 AM
Rhinos7777
Sep 6, 2015 05:36 PM
jbmw002
Sep 3, 2015 08:42 PM
UT G35
Sep 3, 2015 03:58 PM
