they said it cant be done!! THE RADIO
Feb 21, 2007 | 06:28 PM
  #31
Quote: im going to take Aheros spot on this one... SEARCH!! theres a ton of threads covering this topic.
as mentioned, you could do a hi/lo, or (the method Id prefer if it was my car) you can get the signal BEFORE the bose amp, and go Hi-level input to your amp/s and now you have a full freq range to do whatever you wish with. do some homework on this.
hey i seached and only found one just for the speakers/w stock HU not amps and suds
Reply 0
Feb 21, 2007 | 08:13 PM
  #32
Read post #30, and theres you answer why. just ignore the fact that i mis-spelled "typicall".
hahaha
Reply 0
Feb 22, 2007 | 12:08 AM
  #33
it will sound good if you keep the bose HU and the bose speakers, just replace the amp its simple i can email u a picture of the wirering it shows all the colors and what each one is for ,
Reply 0
Feb 22, 2007 | 01:02 AM
  #34
Quote: it will sound good if you keep the bose HU and the bose speakers, just replace the amp its simple i can email u a picture of the wirering it shows all the colors and what each one is for ,
so what amp and would it sound good with 2 10's. i want to replace the 2 tweeters on the doors is that posible
Reply 0
Feb 22, 2007 | 07:08 AM
  #35
alpine makes a good mono block amp, can't go wrong with jl...if you are going to replace the tweeters just replace the complete component...and the rear speakers do need to be replaced because rear fill sound is drastically improved when the stock speakers are replaced...i installed jl zr's in the front and boston pro 60 in the rear...
Reply 0
