veryvery quick question
Old Feb 21, 2007 | 01:28 PM
ELE's Avatar
ELE
is it okay to install my rim and tire without the sensor?.......im goin to install it today......plz help thxthx
Old Feb 21, 2007 | 01:29 PM
dcityjatt's Avatar
it should be fine. however, might have a light go on (and remain on) on your car's dash
Old Feb 21, 2007 | 01:32 PM
ELE's Avatar
ELE
i thought there is a noisy sound coming out from the inside isn't it?....
Old Feb 21, 2007 | 01:42 PM
Big Joe Joe's Avatar
are you serious. why wouldnt you just swap over the tire pressure sensor
do the job right or dont do it at all
Old Feb 21, 2007 | 01:46 PM
BadBoy06's Avatar
^^^ some rims dont allow for our TPS
If you can do it...then do it
Strap method is kinda weak IMO
Old Feb 21, 2007 | 01:51 PM
ELE's Avatar
ELE
u know how much the labour cost if i take my OEM sensor out?and put it into my new rims, but eventually can't fit?........is already cost me 45$ per a tire,\
well i guess i will just install my tire without sensor
thxthx pplz
Old Feb 21, 2007 | 01:57 PM
It shouldnt cost you anything to have them take the sensor out if
your are already R & R a tire
Old Feb 21, 2007 | 01:59 PM
accordfreak's Avatar
Care to explain how it's "weak?"
all rims can accept tps sensors with the straps.
ELE- strap method works great. you should swap it over.
http://www.350zforum.com/net/viewmsg...l&msg_id=81287
https://g35driver.com/forums/showthr...61#post1743461
Old Feb 21, 2007 | 02:04 PM
Calvin's Avatar
Overglorified Altima
i dont have sensors in mine.
Old Feb 21, 2007 | 03:29 PM
BadBoy06's Avatar
My good friend has a wheel/tire shop and stated (too many times to count) straps coming apart from vibrations? 3 different cases the
straps broke and TPS was just spinning around n around.
On 1 case (Acura TL with Volks) strap broke and TPS caused a Blow out
driving at 70MPH. Car slammed into the divider and totaled car but driver
walked away.
Now mind you, could be a bad install
408G35Sedan
Feb 23, 2022 06:46 PM
skippyG
Jan 25, 2016 01:18 PM
Th611
Oct 27, 2015 03:48 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
