who has tokico dspecs???HElp!
Old Feb 21, 2007 | 06:43 PM
savefatkids's Avatar
i need some help. right now all 4 of my shocks are at the stiffest setting. and im thinking i need to loosen up the rears since its sort of hard for me to take tight corners, 1 of my tires get in the air. so im wondering what setting everyone has their shocks on. i dont care about comfort, i just want the best performance out of my shocks
Old Feb 21, 2007 | 07:15 PM
noone has D-specs????? comee onn
Old Feb 21, 2007 | 07:20 PM
FenixL1P's Avatar
go down in stiffness about 3 to 4 turns on the dial and you should be good... although i have sedan i have mine's set to middle of the road... comfort with enough dampening for taking them onramp loops at double the posted speed and nary a hint of body roll (just a little to allow for the inside wheel not picking up)....
Old Feb 21, 2007 | 07:23 PM
Jeff92se's Avatar
Red Card Crew
Wow that's stiff! Shocks are to control the springs. They aren't designed to alter the spring rates! If they are so stiff that the tire lifts off the ground, they aren't doing their job!
Old Feb 21, 2007 | 07:35 PM
so how should i adjust them? do i have to remove my rear shocks? and what about the front? i can adjust the front anytime but what setting should that be at?
Old Feb 21, 2007 | 07:44 PM
Jeff92se's Avatar
Red Card Crew
I'm not sure how you can have these on your car and not know how to adjust them? IMHO I'd start at the middle or maybe 1/3 from full soft and work from there
http://www.tokicogasshocks.com/products/dspec/
Old Feb 21, 2007 | 07:47 PM
i know how to adjust them. just not sure about the back. is there a way to do it without removing the shocks?
Old Feb 21, 2007 | 08:49 PM
BadBoy06's Avatar
x 1000000000
Old Feb 22, 2007 | 09:17 PM
Triple8Sol's Avatar
Only if you have the extensions.
Old Feb 22, 2007 | 09:25 PM
GreenGoblin's Avatar
The goblin resurrection
ya those extensions are a must have
Old Feb 22, 2007 | 09:37 PM
whaat extenisons? and where can i get em?
Old Mar 2, 2007 | 02:21 AM
mondo's Avatar
I set mine about 4 turns from full soft. With Eibach pros, it's just a tad stiffer than stock. You don't need extensions unless you want to play with them all the time... Just pull off the rear wheel, unscrew 2 bolts then pull the shock down and adjust.... less then 10 minutes a wheel. Obviously the fronts just require opening the hood and unscrewing the cap
DRG35R
Sep 16, 2015 05:33 AM
spanky99l
Sep 7, 2015 12:46 AM
TheBay
Sep 3, 2015 03:27 PM
nosam1g
Aug 22, 2015 11:58 PM
linedr89
Aug 17, 2015 05:11 PM
