Lower on Tein Basic, Rear Camber kit must needed?
Old Feb 22, 2007 | 03:55 PM
BadBoy06's Avatar
Originally Posted by Rphillips6487
need cambers if fropping an inch or more most will say.
the best way is to have camberson any drop no matter how much
So I would also think "go for it" get all> toe/camber/a-arms..whats
6-7 more beans...I want my meats to last.
Now it also seems without -camber in back I'll have to roll fenders
when GT-7's come in
Never ending...lol But so much fun
Old Feb 23, 2007 | 06:07 PM
Gdubcp's Avatar
http://www.ajusa.com/cgi-bin/stores/...1fbaafe7d3bd68
is this the one that you said is the same as SPC?
just want to double check
thanks
jason
Old Feb 23, 2007 | 06:12 PM
Skaterbasist's Avatar
Retired SuperMod
Is getting the rear cambers with toe-arms a must?
Or is the rear camber itself good enough?
I understand the purpose of cambers, but im lost with the function of the toe-arms
Old Feb 23, 2007 | 06:14 PM
redlude97's Avatar
thanks
jason
Yes, same one I have on my car currently
Old Feb 23, 2007 | 06:16 PM
redlude97's Avatar
Don't use "toe" arms EVER IMO, get the SPC kit with the toe bolts, or any other camber arms and order toe bolts. The "toe" arms are correctly called radius arms and aren't meant to adjust toe, they are meant to adjust caster on the rear, and toe changes are a side effect of changing the suspension geometry enough that the toe changes
Old Feb 23, 2007 | 06:32 PM
Retired SuperMod
Thanks redlude.
In other words, camber fixes this
And "toe" arm fixes the same issue except on the horizontal plane of the wheel rather than vertical (camber).
Also, what would be the down side of choosing the Stillen Rear Cambers over the SPC Rear Camber with Toe Bolt. In other words, what's the added toe bolt gonna do/not do to my ride and car?
Old Feb 23, 2007 | 06:34 PM
redlude97's Avatar
Thanks redlude.
In other words, camber fixes this / /
The SPC allows you to adjust your camber and toe, the stillen camber arms only allow you adjust your camber, you may be able to get your toe within specs using the stock adjustments, but with a big drop not likely. The SPC kit is cheaper and includes both so I don't see any reason to buy any other brand
Old Feb 23, 2007 | 06:35 PM
Retired SuperMod
Thanks again.
My drop will probably be within the .8 to 1.0 inch range btw
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
beevanhuynh
Jul 23, 2015 01:37 AM
nascarbuff17
Jul 16, 2015 10:23 AM
