unsure symbol light came on the car..
Old Mar 6, 2007 | 05:58 AM
Toofy's Avatar
i was driving on my way to work this morning and mind you it is 14 degrees outside when this light came on as i was backing out of my driveway. It basickly lookslike this " (!) " and im not sure if it warns me about the temp outside but i didnt have tme to check the manual since i am now at work..i was wonderin if anyone fellow members here know what that is?
I hope its something like that cause i just got this car 1 week ago.
thankyou.
Old Mar 6, 2007 | 06:24 AM
6MTzer's Avatar
Check your tire pressure.
Old Mar 6, 2007 | 06:32 AM
Toofy's Avatar
hmmm it seems good.. i was just checking and someone mentioned that it comes on when its cold outside and this morning it was freezing winds so im assumin it should be gone lata when i leave work.
thanx again tho bud atleast i know its no biggie!
Old Mar 6, 2007 | 06:51 AM
bryanmac's Avatar
Happened to me too, scared me a little till I read the manual and found out what it was. When tire warms up, psi will raise and light should go off. I added a few lbs. of air to my tires and never had problems again. I have heard of pressure sensors going bad on this forum, hopefully adding air solves it though.
14 degrees! I don't know how you guys do it.
Old Mar 6, 2007 | 08:20 AM
Toofy's Avatar
haha yeah i know man! its crazi out here in Long Island, NY!
i mean i got out of my car and my face felt like it froze. My face was a little wet from my eyes from the wind being so cold and it litteraly froze lol
Old Mar 6, 2007 | 08:21 AM
GR8TG35's Avatar
That is definitely the Tire pressure sensor....
If you check your tires....they should all be within 2lbs of each other....if they are lower than 34lbs, the sensors will go off....
Make sure you have at least 35 -36lbs, and you should not have any problems.
Old Mar 6, 2007 | 08:47 AM
Toofy's Avatar
great thanx man! ill check after work.
Old Mar 6, 2007 | 08:52 AM
vhtran's Avatar
Look like a butt crack to me hahaha, check for leaking .... LOL j/k , I'm from NE area too, just put few more lbs then u'll be fine
Old Mar 6, 2007 | 08:55 AM
vhtran's Avatar
Don't want to jack the thread, but for those who have after market wheels (w/o TPS valves). Is there a possible way to shut the TPS light?
Old Mar 6, 2007 | 09:37 AM
DanejaPwnz's Avatar
yeah that sign is for tire pressure. In the winter its pretty regular to see that since we all know heat causes air to expand and cold makes the air contract. you shouldn't worry about that too much unless your tires are losing air consistently
Old Mar 6, 2007 | 11:05 AM
Sac2904's Avatar
Yup, seem like we all have the right answer. Tire pressure warning sensor. Some time when the weather temperature outside is way too cold, my tire sensor would be on for few mins and it would automatic off. Dont put more air in these tires unless the warning sensor is still on for a long period of time....
Old Mar 6, 2007 | 11:10 AM
papiloco21's Avatar
(_!_)
Old Mar 6, 2007 | 12:08 PM
Toofy's Avatar
arite great.. i was driving for about 15 minutes to work today and it was on as i was pulling out of my drive way and it was still on while i parked in the lost at my job.
i get of in a few hours so ill be sure to check to see if it still occurs when i drive home.
Thanx everyone i appreciate this got me a lil worried ii didnt know caus my BMW does the same thing but it flashes the temp let me know its cold out :P
Old Mar 6, 2007 | 12:10 PM
Calvin's Avatar
Overglorified Altima
nope
Old Mar 6, 2007 | 01:39 PM
vhtran's Avatar
Originally Posted by papiloco21
(_!_)
Some got flat butts
