need some help... engine..
Old Mar 10, 2007 | 12:20 PM
FaDz's Avatar
VIP
I just got my G back... I installed the Skunk spacer, Nismo Headers, HKS exhaust.... and I had the intake on from b4.... now the problem is, I took the dar out for a spin... and my SERVICE ENGINE light came on... what could be the reason... could be a bigger problem ? and I saw the thread for restarting the CPU will that work ?
thanks...
Old Mar 10, 2007 | 12:28 PM
filanj's Avatar
All those mods have A LOT of potential for leaks. Don't reset your ECU until you can get a reading off of an OBDII. Take it to PePBoys or someplace to get it read. I have a feeling it will be a leak, so be ready to take it back to where ever you had all your mods installed. Your ECU should have been reset right after having those mods installed, so your ECU can learn new from the start instead of having to remap old maps.
Old Mar 10, 2007 | 12:31 PM
FaDz's Avatar
VIP
so I shouldnt follow https://g35driver.com/forums/engine-drivetrain-forced-induction/6526-easy-ecu-resetting.html ......
that thread?? just take it back to get it checked? a leak..... ?!?
Old Mar 15, 2007 | 10:38 AM
FaDz's Avatar
VIP
is was the O2 sensors... what would cause that problem ?
Old Mar 15, 2007 | 10:48 AM
raff's Avatar
o2 sensors are very sensitive. it could have gotten damaged while being taken off or put back on. either that or you have a leak somewhere.
Old Mar 15, 2007 | 04:50 PM
Ha_ze_G35's Avatar
I don't know enough about the G yet, but with my last car (mitsubishi lancer) the car would get set off with new headers because there were two O2 sensors and new headers never had the spot to replace the first sensor.
I'm hoping it's not the Skunk spacer cause mine is getting installed next week
Old Mar 16, 2007 | 04:26 PM
FaDz's Avatar
VIP
hmmm.. all i know is its the 02 sensors.. theres no leak... i guess i have to get more depth on why it would be damaged...
Old Mar 16, 2007 | 04:37 PM
filanj's Avatar
Sounds like you need O2 spacers. Are you running test pipes with your HKS? If so, than that would be causing the CEL.
Old Mar 16, 2007 | 05:57 PM
BadBoy06's Avatar
check to make sure its seated properly..sensor that is
Old Mar 20, 2007 | 01:53 AM
FaDz's Avatar
VIP
no .. no test pipes..
KevinnnVo
Oct 14, 2024 04:33 PM
TheJudge
Dec 29, 2005 06:02 PM
3 DOWN
Dec 3, 2005 06:06 PM
Eurog35
Apr 23, 2004 04:20 AM
Shooby43
Jul 15, 2003 04:16 PM
