Strictly Z Aluminum Pedals - Installation Help!
Old Dec 9, 2003 | 11:36 PM
6MT_Coupe's Avatar
I was trying to install the aluminum racing pedals from Strictly Z into my G35 coupe tonight (manual) and came into some difficulty getting the clutch and brake pads on. These things were just impossible to get around the metal plate. Any suggestions from those that have successfully installed them?
I am going to try to use my friend's garage tomorrow because he has an outlet and I am going to try using a hair-dryer to soften the rubber so that it is easier to get around the metal plate... Any advice appreciated...
Thanks... One frustrated G-owner.
Here's to alcohol : The cause of ... and answer to all of life's problems.
- Homer Simpson
Old Dec 9, 2003 | 11:41 PM
ducatiguy's Avatar
Premier Dough Slapper
Re: Strictly Z Aluminum Pedals - Installation Help
Ha Ha Ha - Join the club!
Those things are annoying to put on, but they will go on. Just takes a little finess. I don't know if a hair dryer will do much, but you can give a shot.
"See, the problem is that God gives men a brain and a *****, but only enough blood to run one at a time."
Old Dec 10, 2003 | 12:02 AM
nate's Avatar
Re: Strictly Z Aluminum Pedals - Installation Help!
I used a hair dryer and screwdriver to pry them on and also found it helpful to put them on slightly diagonal and twist them on. Others have also used soapy water or a little grease/oil.
Good luck!
2003.5 Sedan Black/Black w/ sport, premium, aero, and winter packages. See my profile for updated mods list and pics.
Old Dec 10, 2003 | 12:22 AM
TINMAN's Avatar
i spray some of wd-40 on the rubbers, slip right on for me
Old Dec 10, 2003 | 12:25 AM
RashMan1450's Avatar
was just about to say use WD-40. THat helped out alot.
2004 Diamond Graphite G35 Coupe 6MT, Premium Package, Aero Package, DVD Nav
Old Dec 10, 2003 | 01:19 AM
6MT_Coupe's Avatar
Perfect.... Thanks a lot guys.... I will try WD-40 and hopefully I will not have blistered fingers tomorrow!
- Homer Simpson
Old Dec 10, 2003 | 01:27 AM
OOOOA3's Avatar
Alumni****
yeah.. i did it w/o using WD-40 but it was a big b*tch to put them on that way.. later i did an install for someone and man, jus using some WD-40 made the install 10 times easier..
Old Dec 10, 2003 | 01:46 AM
JAG35CP's Avatar
Boiling water with soap worked great.
Old Dec 10, 2003 | 06:59 AM
g35audioman's Avatar
i just used a hair dryer...i went in my house, used the hair dryer for all the pedals, then came out and put them in in about 5 minutes. It softens it up for a while so you dont really need an outlet in the garage for this to work. Its really easy. Just use the hair dryer for about 2-3 minutes per pedal and you should be fine. Watch the metal though since that obviously can burn your skin off after using the dryer.
Old Dec 10, 2003 | 11:10 AM
carmeljoy's Avatar
i soaked the pedal in hot, hot water instead, eaiser to do then hair dryer. and used vasaline sparingly instead of wd 40. i did want the smell of the wd to interfere with my new car smell! use a short flat screwdriver. hook the lip on one corner furthest from you and work the blade accross the top and bottom towards you. it will come eventually. takes about 10 to 20 minutes. just get your girl to massage you back afterwards, trust me it will be killing you.
don't start no sh*t, won't be no sh*t!
'04 g35c DG/G 5AT premium, performance, aero kit, pedals, clears
Old Dec 10, 2003 | 12:08 PM
6MT_Coupe's Avatar
Two questions:
1) For those that used WD40, did the smell linger in your car? If so, how did you go about removing that smell?
2) Where did you apply the WD40?
- only on the metal pedal plate?
- only on rubber on the alumimum covered pad?
- on both?
Thanks.....
- Homer Simpson
Old Dec 10, 2003 | 12:43 PM
TINMAN's Avatar
1) it did smell a bit,but went away by itself the next day.just don't spray too much.
2) apply on both.use gloves or piece of rag to handle pads while install (slippery)
btw,it took me less than 10 mi. to complete the job. good luck
Old Dec 10, 2003 | 12:56 PM
gsg's Avatar
gsg
I installed it the same as Carmeljoy did, with vasoline. I didn't want the WD40 smell in my car. It is a little difficult but eventully went on.
I was wondering, does StrictlyZ supply the gas pedal clip with its kit these days. When I bought my kit from them several months ago they claimed all parts were included; however when I went to install it I found they did not supply the gas pedal clip, they claimed they couldn't get it, and advised people to cut off the old one and use it. How mickey mouse! I went to an Infiniti dealer and bought a new clip.So it cost me more $$ and time.
I've noticed Grubbs sells the kits for about the same price and includes all parts including the clip - so I would direct people to buy it from Grubbs.
Old Dec 10, 2003 | 02:16 PM
6MT_Coupe's Avatar
Hi all,
I just got done putting on the clutch and brake pedals... My fingers are so sore that I can barely type (my sad story.. haha)... But I did use the hair dryer trick and it worked really well. I got both pads on with less than 10 minutes of effort, and there is no smell of WD40 or vasoline in my car.
Now I am waiting for Strictly Z to send me the gas pedal. They forgot about this one, and no they do not provide the clip. They want you to reuse the clip that is already there.
Did anyone else (who ordered from Strictly Z) have a problem reusing the clip?
- Homer Simpson
Old Dec 11, 2003 | 12:33 AM
carmeljoy's Avatar
i got my pedals for grubbs and the new clip comes included. but honestly unless u damage the old clip you should be able to use it again with no problem.
