Bad problem tonight
Old Dec 25, 2003 | 02:05 AM
rayl's Avatar
Bad problem tonight
I started my car and the Engine Service, Slip, and VDC Off lights stayed on. Started driving and could not accelerate or even hit 30 mph after the car was fully warmed up. I made it home but would appreciate any input or advice about this problem.
2003 Black Coupe AT
Old Dec 25, 2003 | 02:18 AM
ericinmia's Avatar
Re: Bad problem tonight
I am by far no expert on cars but this info my help others figure it out too...
Temp outside
Time car was sitting there
modifications done to car
last fluids check...
Try unplugging the battery and letting it sit overnight... (negative terminal) This will reset some things, might help...
Merry Christmas!
-Eric
'03.5 Silver/Black | Prem | Perf | Aero | Stillen Hi-Flow | Z -Tube | Grounding Kit | Nismo Oil/Radiator Caps | Solid Allum Pedals | Diamond Matts | Tints | Valentine1 | Hide-Away License Plate!
Old Dec 25, 2003 | 02:27 AM
rayl's Avatar
Thanks Eric,
Outside temp. 25 degrees
Car sat for about three hours
Fluids checked last week
No mods
Merry Christmas
Ray
Old Dec 25, 2003 | 02:56 AM
Triji's Avatar
I agree, try a ECU reset. Unplug the negative battery terminal and let sit for 12 hrs. Then see what happens when she wakes up. Good luck and have a happy holiday.
2004 Coupe, 5AT, Twilight blue / Willow int, K&N Typhoon CAI, Hyper Grounding Kit, Mtek Xenon Fog/High, Clear corners, Hypers, 18's, Aero, tint, Premium.
Old Dec 25, 2003 | 09:54 AM
Merlin's Avatar
Staff ALUMNI
Sounds like the 'brake switch'. There is a TSB and some info in the TSB Board. The dealer will fix w/o a problem. Good Luck and keep us posted.
Andrew, We Miss and Love You! Peace!
Old Dec 26, 2003 | 11:02 PM
rayl's Avatar
Merlin,
Exactly correct, it was the brake switch. The service advisor at the dealer said that the car went into fail safe mode. I strongly recommend that anyone who hasn't had this fixed do so ASAP. It was not fun driving with my three year old daughter in a car that can't accelerate or even hit 30 mph.
Thanks for the tip,
Ray
03sedang35
Aug 29, 2015 07:56 PM
saskicker32
Aug 11, 2015 02:12 PM
newg37
Jul 26, 2015 09:32 AM
