Window Rattles
Old Dec 28, 2003 | 07:18 PM
clm288's Avatar
Window Rattles
Has anyone had any trouble with the driver side window making creaking/popping noises while driving? The dealership has already done several things and it is still doing it.
Old Dec 28, 2003 | 08:58 PM
Serum's Avatar
Re: Window Rattles
i haven't had problems w/the window, but more or less the storage area in the drivers side door. i hear it rattle when i play songs w/extreme bass. i lean my left knee on the door and it stops. i'm sure it's an easy fix.
i have however noticed my sunroof making noise as if it's not lubed properly. i'll have to ask the dealer about that.
Old Dec 28, 2003 | 09:10 PM
Speedoholic's Avatar
G (enie) FUNK ERA
Re: Window Rattles
I have been noticing a rattle from my driver's side window when it's half way down, like when I roll down the window but not all the way. Then while driving with the window at that position, I will get rattles when driving over bumps and pot holes.
I guess I'll have the dealer check it out on my up coming first oil change.
2004 G35C 6MT DG/Gr/Prem/NAV/A.Pedals/C.Corners/C.Bra/PIAA [img]/w3timages/icons/cool.gif[/img]
Old Dec 28, 2003 | 09:49 PM
clm288's Avatar
Re: Window Rattles
I also had problems with my sunroof when I first got it. It still makes excessive wind noise, as if it is leaking. Also, I have the same trouble with my radio when it is loud, it vibrates along the speakers. I am glad it is not only my car this is happening to. It should not be happening at all. Thanks.
Old Dec 30, 2003 | 01:34 PM
lloyd's Avatar
Re: Window Rattles
I had creaking problems with both the driver's and passenger windows. There is a TSB on it. The dealer replaced both window mechanisms. No problems since.
g35C-White, Colorado GGGGONE
Old Dec 30, 2003 | 04:07 PM
atlgfreak's Avatar
Re: Window Rattles
i have the same problem with my drivers windows, need to take it in after the new year. also have some rattles on the same door when i crank the stereo.
2003 G35 Coupe, 6sp, Laser Red, Willow
1992 Cherokee Sport Red (daily driver)
Dallsinghjr1
Sep 17, 2023 11:25 AM
Picture Share
Feb 4, 2018 12:41 PM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
Learned Hand
Oct 1, 2015 09:02 AM
