Is my car burning rich?
Old Jan 4, 2004 | 06:20 PM
Tybrey's Avatar
I have 3000k miles on my 04 coupe. I mostly drive highway miles. I avg 19-20mpg. But, today I noticed I had a lot of black sut in and around my exhaust tips and a little on my bumper. I was always told that if you see a lot of black sut in your exhaust tips, than that means that you do alot of city driving or that you are burning rich. Is this normal for this car? I assume that everything is OK assuming that I didn't get a check engine light. My air intake is stock. I need to know if this is normal before I install my 350z tube and JWT popcharger.
"Not all G35 owners are G35 Drivers"
2004 G35 Coupe 6MT-BS/BLK | Aero-Navi | Gounding Wires (Hidden by black conduit) | Clear Corners | Not Installed> 350Z Tube | JWT PopCharger...
Old Jan 4, 2004 | 09:04 PM
ericinmia's Avatar
Re: Is my car burning rich?
All g's are like that...
I heard they come slightly rich from the factory.
-Eric
'03.5 Silver/Black | Prem | Perf | Aero | Stillen Hi-Flow | Z -Tube | Grounding Kit | Nismo Oil/Radiator Caps | Solid Allum Pedals | Diamond Matts | Tints | Valentine1 | Hide-Away License Plate!
Old Jan 5, 2004 | 02:08 PM
uheenada's Avatar
umm... 3000k miles???
1k = 1000miles
so your saying 3,000,000 miles??
WOW i didn't know our g's can run that long?
j/k i know what you mean.. you probably said 3k...
Old Jan 5, 2004 | 06:12 PM
MontrealCoupe's Avatar
It's the same with mine, but it got a little better after a few 1 000 miles. Every new car burns a little more oil in the first miles it does.
Old Jan 5, 2004 | 08:16 PM
6MT_Coupe's Avatar
The soot on your exhaust is either coming from the gasoline or the oil burning... Therefore, by adding an intake, you are only varying the O2 going into the engine, while the amount of gasoline stays constant....
Therefore, wait until you have a couple more miles on it and see if it keeps happening consistently... Many people on this site have added aftermarket intakes which add more air to the combustion chamber and have not had any problems.... Better to be rich than lean ya know!
Here's to alcohol : The cause of ... and solution to all of life's problems.
- Homer Simpson
Old Jan 5, 2004 | 08:59 PM
Tybrey's Avatar
Yeah, I meant 3k. Thanks
Old Jan 6, 2004 | 02:30 PM
BaitFish's Avatar
Carbon condenses out of the exhaust gasses onto the cold pipe. You can see this effect if you hold a match or lighter up to an aluminum can. Now if you're getting A LOT of black deposting on the paint surfaces around the exhaust there's probably something wrong but I'd imagine the OBDII would catch it before that.
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
newg37
Jul 26, 2015 09:32 AM
lemmy999
Jul 25, 2015 12:13 PM
justgotg35
Jul 19, 2015 12:33 PM
mjfenix
Jul 17, 2015 02:07 PM
