was using them and noticed the light on the switch only is illuminated on low heat. when i switch to high heat, the low still stays lit. this is on both left and right.
is this normal
why would there appear to be a light for high
04 6mtC, DG - possibly most babied G on the board.
is this normal
The light is only on the low side. There is a small low mark on the switch and a larger mark on the high side, the light is just above the low mark. This is how it should work.
Lou
Lou
i noticed that today also when i was using it.
if the upper light doesn't turn on, then why is it even there?
Coupe 6-spd Twilight Blue/Black Premium
There is only 1 light
04 G35C DG AT
Prem Aero Perf
V1
Blizzaks
R splash Guards
Long Island, New York, USA
04 G35C DG AT
Prem Aero Perf
V1
Blizzaks
R splash Guards
It does work, high and low but there is only one light indicating that it is turned on.
Im used to heated seats that actually get warm. These should actually be called "low" and "lower".
'03.5 Silver / Willow Coupe, 6MT, Prem, Nav, Aero Package and Kit
i.love.gold
Mine get pretty warm...if I have it with windpants on, it can get uncomfortably hot.
Ivory Pearl coupe
Ivory Pearl coupe
anyhow, at least we have seat warmers rite?
For some reason, I've noticed that mine don't get as hot, until the car starts moving. If I'm sitting at a light, I hardly notice it is on, but then once I get up to hwy speeds, they start cooking.
Guest
yo guys, some G owners on this forum have had problems with their seat heaters not working. Don't mistake your own normal body warmth for the *** warmers....when you put it on High, these *** warmers get hot !!!! But they are timed, so once they get really hot, they will shut off for a while. Best way to test if your *** warmers are working is to sit in your car witout a jacket and drive around with the *** warmer on high...if your *** and back do not get uncomfortably hot after 10 minutes, your *** warmers are not working !!
MrElussive
03 G35C 6MT
MrElussive
03 G35C 6MT
I've actually noticed the same thing--- when the car is moving, the seats seem to be warmer. Go figure.....
I can turn the car on and the seat warmers on, and they don't get very warm very quickly, but then start driving and they warm nicely.... strange but true.
Maybe we've got 'SCH' (speed sensitive control heat) -- similar to our SCV on our radio. [img]/w3timages/icons/tongue.gif[/img].. J/K
I like my seat warmers, I wouldn't be without them up here in 'The Trundra'. Only improvement I'd make to my ride is to add a steering wheel heater like I had in my Max.
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
<font color=red>GSM</font color=red> <font color=black>Silverstone Coupe</font color=black>
If yours isn't working, you may have a 2003 coupe that needed the seat warmer wiring harness changed according to the TSB from Infiniti. I had that done with my first maintenance a while back. Some coupes had the wiring reversed so that the Left button controlled the Right seat and vice-versa.
Dr. Jim
2003 DesertPlatinum/Graphite G35C 6MT
Aero/Prem/Nav/HyperGround/XMSat/BSM/Tint/ClearBra/CG/NismoChromeShifter/RacePedals/Z-tube/JWTPopCharger
Dr. Jim
G SQUAD
Yea but the same holds true with the heat no? The heat really doesn't kick in when ur stationary. When ur driving though then you feel the heat blasting. Anyway thats what I have noticed
WRAH
My 2004 get almost too hot, when I turn them on its always low!
"What if there is no tomorrow....There wasn't one today!!!" Bill Murry
Dr Jim, Thanks for the heads-up on the TSB. I do remember it and checked mine at that time to discover that they work as they should. They're just a little slow to heat, and seem to be tied more to vehicle speed than time.
I'm reasonably comfortable (pun intended) with the way they are-- I don't really want them to heat up more than they do, tho a little quicker would be welcomed.
I'll have to talk to my dealer about a possible mod.
