Grounding Wires = Low RPMs?
Old Jan 16, 2004 | 11:59 AM
max2DGG's Avatar
Hey, I installed grounding wires on my car a while back, and ever since, my car idles usually at 3-400 compared to i believe 800? well i read something about grounding wires making your car's idle a bit lower, but i was wondering if this was actually so. If this is not, is there some way i can reset something to make my idle normal. please help. thanks
Old Jan 16, 2004 | 12:13 PM
Speedoholic's Avatar
G (enie) FUNK ERA
Re: Grounding Wires = Low RPMs?
If you want, you can take it to the dealer, and have him take a look at it, and if necessary - tune it.
2004 G35C 6MT DG/Gr/Prem/NAV/A.Pedals/C.Corners/C.Bra/PIAA/Grnd.Kit [img]/w3timages/icons/cool.gif[/img]
Old Jan 16, 2004 | 12:15 PM
intruder's Avatar
I wonder if an ECU reset would fix this....
2004 G35C 6MT, Black/Willow, Prem, Aero, Nav, on a truck somewhere in TX, INBOUND!
Old Jan 16, 2004 | 12:32 PM
SixFive's Avatar
It's more like 500 - there is no way to gauge between 0-500. IF the idle is lower as it is in mine and also not sputtering it wont matter. It should be lower and smoother...some also have speculated that it's just a more accurate reading on the guage as the analog insturments are actually "wired".
Dont worry - hundreds of folks have said that about the idle dropping. No tune ups until at least 36k miles...
Old Jan 16, 2004 | 01:27 PM
Gordgee's Avatar
Administrator
Remember, that first mark on you tach is 500 RPM. If your car is idling smoothly between that and 1000 RPM, it doesn't need to be fixed.
<font color=green>GroundingGear™ Equipped </font color=green>
Old Jan 16, 2004 | 08:16 PM
6MT_Coupe's Avatar
Gordgee,
Why would grounding the car lower the idle RPM of the engine?
I personally don't think you are just getting a more accurate reading of the engine RPM... I am not saying that I know this for sure, but as an electrical engineer it just doesn't make any sense...
Here's to alcohol : The cause of ... and solution to all of life's problems.
- Homer Simpson
Old Jan 16, 2004 | 08:28 PM
intruder's Avatar
This may have already been covered in the forum, but are the wires worth it and are they easy to install?
"Some mornings it just doesn't seem worth it to gnaw through the leather straps." -- Emo Phillips
Old Jan 16, 2004 | 08:46 PM
Gordgee's Avatar
Administrator
For a quick read:
Hyper-Ground FAQ Thread
I've been asked to collect and post some of the feedback on the FAQ from actual users, so it would be easier rather than read though the entire >2 hour thread. I'm currently compiling.
If you're otherwise bored and can't sleep:
H-G Monster Thread
Old Jan 16, 2004 | 08:57 PM
Gordgee's Avatar
Administrator
"Why would grounding the car lower the idle RPM of the engine?"
The feedback that I've gotten is that it can lower the idle on some cars, but usually not to a significant degree. Usually the ECU tends to raise the idle to ensure an efficient, smooth idle, such as on initial startup on a cold engine. When it reads that the engine is running smoothly (no stumbling, etc.), it lowers the RPM if it can maintain the optimal parameters for the idle conditions present. Since the H-G system optimizes the overall efficiency of the running engine (which may explain the reported smoothness throughout the rev band), it would follow that the engine is able to idle at a slightly lower RPM.
Does this make sense to anyone else?
Old Jan 16, 2004 | 11:36 PM
6MT_Coupe's Avatar
Hi Gordgee,
I have read through the post that you indicated several times, and I read your explanation... I guess that sounds reasonable if the ECU is continuously monitoring the "engine smoothness" (whatever physical or electrical measurement that is) and then has a control system that automatically adjusts the idle RPM for gasoline efficiency.. This is getting a little deep into it, but I really wish I knew what was really going on...
BTW, I am also going to get a grounding kit in the near future (month or so)...
- Homer Simpson
Old Jan 17, 2004 | 12:49 AM
Gordgee's Avatar
Administrator
I've passed the theories past several EEs as well as several auto electrical techs. You have no idea how much time I spent, especially in the early days when I was a skeptic as well to get some answers. Lots of 'ah-ha!' moments! I think some of the nitty gritty re H-G theory could be someone's thesis one day. I'm actually going to cut and paste this Q&A on the FAQ for others to ponder as well so this doesn't get lost.
Old Jan 17, 2004 | 03:48 AM
6MT_Coupe's Avatar
sounds good... I would love to hear it.
- Homer Simpson
Cskeet
Drivetrain
Dec 3, 2015 09:18 PM
03sedang35
Aug 29, 2015 07:56 PM
Bean_VQ35DE
Aug 22, 2015 09:56 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
