Bent Rod ?
Old Jul 12, 2007 | 02:33 PM
vinnys coupe's Avatar
Bent Rod ?
Hello im looking to buy a g35 coupe auto (03). Gorgeous car the guy is asking for a low extrmeley low price, 15k. But he was telling me that it has a bent rod and it is not driveable. He said they bent the rod driving in a flood. How legit do you this this seller is. And how bad is a bent rod and how much would it be to buy and install another rod.
If any1 knows where to buy a rod for an 2003 couple AT please post below thanks.
Old Jul 12, 2007 | 02:54 PM
vjquan's Avatar
Bent rod from driving in flood means hydrolock. Water got in the engine and did some internal damage. Also damaged are probably some pistons and valves. You're looking at a new motor, not just a rod.
Old Jul 12, 2007 | 03:18 PM
He told me that the person went through a puddle and bent the rod. Im not axactly sure what the damage is but i also think it would be more than a rod. Is there a rod that would prevent the car from driving.
Old Jul 12, 2007 | 03:25 PM
05BLACK6MT's Avatar
VQ engine rod is the weakest link for this engine. So it very posible the rod is bend when the engine take in water. The rod is the piece that conected to the piston and crankshaft. when the the rod push the piston up and the cylinder is full of water and water is not compressable so something gotta gives. in this case it the rod that gave in. Hope that help
Old Jul 12, 2007 | 03:55 PM
madscientist's Avatar
in other words.
DON'T BUY THIS CAR
Old Jul 12, 2007 | 04:22 PM
partyman66's Avatar
15K for an '03 that doesn't run and was involved in a flood is a horrible ripoff considering you're looking at many thousands of dollars in motor replacement/repair costs.
Why pay good money to buy someone elses problem?
Old Jul 12, 2007 | 04:38 PM
yes that helps
thanks
Old Jul 12, 2007 | 04:39 PM
well thats what im trying to find out. If its not alot of money then i may consider it, but if alot of money i would not consider it. Thats why i started this thread.
Old Jul 12, 2007 | 05:19 PM
FI'ed G's Avatar
What is the book value of the car? You can buy a short block cheap now a days and for a few more thousand you can have a built short block for under8K and you are ready for boost make sure that this thing didn't really went to a high flood coz you don't want an entire car soaked in water.
Old Jul 12, 2007 | 07:37 PM
It has 53k miles perfect interior and perfect exterior. Its an base model coupe no navi no aero package. Just base model
Old Jul 12, 2007 | 09:19 PM
DrrSeuss's Avatar
I bought mines with 48k miles running in perfect condition for 18k...the 15k price tag is way too high.
Old Jul 12, 2007 | 09:32 PM
chilibowl's Avatar
Dont buy the car. There are many other cars out there that are NOT damaged. Why would you put yourself into a financial situation you know will put you in deeper with repair costs. Find another vehicle, it is simple as that.
Old Jul 12, 2007 | 11:58 PM
yes true.. thanks for your opinions i will keep looking around..
thanks guys
Old Jul 13, 2007 | 12:01 AM
ttrank's Avatar
Grocery getter
+1, that is not a good deal. If you had plans to build the motor for turbo(s) it would be worth dealing for.
Old Jul 13, 2007 | 03:08 PM
truee^^^^
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
prinny
Nov 22, 2015 11:07 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
5150DS
Sep 26, 2015 07:47 PM
NJ6MT
Sep 10, 2015 08:40 AM
