ATI procharger sound normal? *VIDEO*
Old Jan 27, 2004 | 08:42 PM
CoolCatGee's Avatar
Does the grinding/rattling noise sound normal listen carefull for what im talking about
http://www.igride.com/supercharger.WMV
Old Jan 27, 2004 | 09:44 PM
waijai's Avatar
i.love.gold
Re: ATI procharger sound normal? *VIDEO*
I've heard two ATI coupes and they both do not sound like that. Too much excessive metal to metal noise.
Ivory Pearl coupe
Old Jan 27, 2004 | 09:48 PM
CoolCatGee's Avatar
thank you for the reply, you think its the blower then?
Old Jan 27, 2004 | 10:26 PM
jdl75's Avatar
I hear two things:
1. I hear a belt out of alignment.
2. I hear bearing noise, most likely caused by #1.
Granted, I'm listening to a less than perfect recording on lousy laptop speakers, but there is something unmistakable about belt and bearing noise. The higher-pitched noise sounds like the side of the belt rubbing on a puley. Screw up a couple alternator installs and you'll learn this noise! Check the alignment of everything, make sure nothing is bent or shiming something out of alignment.
The lower-pitched oscilating sound seems to bearing noise to me. Just a hunch.
Old Jan 27, 2004 | 10:33 PM
CoolCatGee's Avatar
i think your right one of my pulley is giring up on one side of a pulley but i dont have a shimm do you know what i can use as a "makeshift" shim?
Old Jan 27, 2004 | 11:38 PM
zimbo's Avatar
The high-pitched whine sounds comparable to the sound of my Vortech (perhaps a bit louder than mine), but there's a lower pitched metal rattle that doesn't sound right at all.
--Steve
Old Jan 27, 2004 | 11:55 PM
Need4Speed's Avatar
1. your cog belts maybe too tight (should be .4 for cog belts compared to .2 for the v belt)
2. you put oil in the blower right?
good luck,
rob
03 G35C auto nav, alum. pedals, grounding kit, ultralight battery, Z tube (x), crawford plenum, RT cats, borla, ATI Procharger, CF Intake, TurboXS cbv, J&S Boost/Knock
cmesidewayz
Sep 29, 2015 09:28 PM
yosip1115
Sep 9, 2015 03:30 PM
G35CO
Sep 4, 2015 09:27 AM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
