rattling...
Old Sep 14, 2007 | 12:57 AM
Mr.Bojangles86's Avatar
Does anybody else get a rattle from their moonroof when it is on tilt? Cause i think that's where the sounds coming from.
Old Sep 14, 2007 | 10:37 AM
joe603's Avatar
My sunroof rattled until I applied some 3M spray silicone...nice and quiet now!
Old Sep 14, 2007 | 01:53 PM
MrXpSyChO's Avatar
Originally Posted by brooklynite
i get the same noise when i accelerate in low rpms. sounds like metal vibrating from underneath the car. sometimes the noise is embarassing. my 95 dodge neon used to have this sound but it's a neon.
what bothers me also is when i'm idle and in neutral..i hear this rattling from underneath the car that i suspect that has something to do with the clutch. when i disengage the clutch, it goes away. let go of the clutch, it comes back. let it rattle for about 5-10 mins and it eventually goes away. what is this?!
I have the same exact problem. comes and goes. honestly, it is kinda hard to hear from inside the car (unless you know what to listen for), but i feel so embarrassed when i'm driving in like a parking lot and i hear that clicking. for me, if i rev too high in 1st (like over 2k) and let the clutch go too slowly, then that noise is freakishly loud (especially somewhere that echoes, like next to a big wall). bleh... well, i'm at the Infiniti dealership right now for an oil change, and I told them I had rear axle clicking. I have to reschedule for the axle clicking (which they said is covered under the warranty), hopefully tomorrow. I agree with you, thinking the noise came from the clutch, but then again, I have no idea. Hopefully the rear axle IS the problem, so that they fix it and it goes away...PLEASE!! i freakin hate that noise...ugh...
Old Sep 19, 2007 | 05:16 PM
BurntRenolds's Avatar
So do I...Can somebody please post a DIY on this (greasing the Bushings)...
Old Sep 19, 2007 | 06:44 PM
GR8TG35's Avatar
Do our cars have aluminum heat shields over are exhaust system?
I had a RX7, and a couple years into ownership I started getting this annoying rattle/buzz sound when I took off in 1st gear.
It turned out to be the aluminum heat shields....the mounts broke, causing the pcs to vibrate under accerleration etc. I had to Clamp them down with hose clamps to the mounting points to eliminate the buzzing.
Maybe a heat shield is loose.....I never had the opportunity to look under my car, so its a possibility?
Old Sep 21, 2007 | 05:13 PM
shawnn125's Avatar
Yes, there is a heat shield and i confirmed the rattle to it.
banging it helped for a while but it came back...
will have to call dealers..
funny this this all started exactly one of owning the car..
Old Sep 24, 2007 | 05:52 PM
I also confirmed today that the rattling noise (sounds like a chain being dragged) was confirmed to be the heat pads. Many rattling noises can arise but the description (chain being dragged) is common to the heat pads. I hoisted the car with someone in it and found that the heat pans were in fact rattling while my mechanic was revving the car. Some pressure on the (very hot) heat pads would stop it. Nothing serious but the annoying sound is going to drive me crazy so I'll be buying some metal clamps to secure them...
Old Sep 26, 2007 | 10:53 AM
TR11's Avatar
My shifter rattles audibly louder than the exhaust note on accel. It drives me nuts.
Any cure for this?
yosip1115
Engine - Exhaust
Aug 22, 2013 03:42 PM
WhatsG05
May 20, 2012 05:02 AM
2GoRNot2G
Jun 25, 2009 04:00 PM
mal_TX
Apr 14, 2006 06:11 PM
mary6MT
SouthEast
Jan 18, 2006 03:36 PM
