Please Help! Coupe higher on one side after jacking.
Old Sep 15, 2007 | 03:10 PM
The1&Only's Avatar
Exclamation Please Help! Coupe higher on one side after jacking.
I need some help. Last night I put my new wheels on, and now my car is lower on the driver's side than the passenger's side after jacking the car. Anyone know how to fix this? You can tell when you stand behiond the car that it's leaning to one side, plus i measured the wheel gap on both sides, and there is a difference.
Old Sep 15, 2007 | 03:26 PM
kyu1021's Avatar
did you try driving the car after you put the wheels on? once you drive it, it should settle out.
Old Sep 15, 2007 | 03:30 PM
The1&Only's Avatar
Yea, i've driven it twice now.
V35 Skyline GT's Avatar
6MT Coupe
Yup...what he said. Works everytime.
Oops ya beat me on posting.
Thats the only thing it could be unless your new tires are different dia. from one another
Old Sep 15, 2007 | 03:36 PM
The1&Only's Avatar
i've driven the car twice now, but only it short distances.
Old Sep 15, 2007 | 03:39 PM
The1&Only's Avatar
i checked, and they're the same size.
Old Sep 15, 2007 | 03:48 PM
6MT Coupe
Hmm...know when I installed my coilovers, dampeners were pumped up or something like that.
Drove on them for a bit. Bumps helped settle them down.
How much off in wheelwells?
Mine stock everything were not perfect as far as space went and with drop, was off only a small amount.
Old Sep 15, 2007 | 03:51 PM
The1&Only's Avatar
I'm on stock suspension. The difference isn't that much, but it's noticable.
Old Sep 15, 2007 | 03:55 PM
The1&Only's Avatar
Do you think I should try jacking up the driver's side to see if that will even it out, or just wait after driving around today to see if it settles?
Old Sep 15, 2007 | 03:58 PM
6MT Coupe
Stock suspension dampers can get pumped up or whatever, like aftermarket dampeners can. Thats why I mentioned my situation.
All I can suggest is to take your G out on another run, longer this time and drive on road with bumps, dips, etc. Then things should settle out back to stock stance and clearance.
G/L
Old Sep 15, 2007 | 04:09 PM
The1&Only's Avatar
Thanks for the help. I'm not much of a suspension guy. The handling doesn't feel any different, it just looks kinda wierd though since the car's leaning slightly to one side. I'm gonna be getting a drop though soon.
Old Sep 16, 2007 | 12:51 AM
myv6isfaster's Avatar
is it really noticeable though? i believe you could be on uneven ground as well?
Old Sep 16, 2007 | 09:00 AM
tekknikal's Avatar
thats odd if you're on a stock suspension.
i was having the same issue but i have hks rs and the suspension settings seemed off.
i suggest you check tire pressures. if not that, go somewhere where you know the ground to be perfectly level.
Old Sep 16, 2007 | 07:07 PM
bassholic's Avatar
put your stock rims back on
Old Sep 16, 2007 | 08:11 PM
jclit's Avatar
Ya after i put my springs i had he same problem and till this day its like that
wonderizm
Sep 24, 2015 03:09 AM
lemmy999
Jul 25, 2015 12:13 PM
si_driver
Interior
Jul 25, 2015 09:22 AM
