Auto Shutoff headlights?
Old Feb 18, 2004 | 10:34 PM
dopeymon's Avatar
Re: Auto Shutoff headlights?
GOOD POINT I WAS JUST THINKING THE SAME.
when i put my light as ON.... then when i go turn off the lights... it has to go pass PARKING lights which turns off headlights... then when i go into AUTO the lights goes back on... then goes to OFF. Doesnt seem too good for the xenon~!
Old Feb 18, 2004 | 11:19 PM
xasnxkiddox's Avatar
Same thing for turning on the headlights from the "off" position as well. It goes through auto then parking lights then headlights. Seems like the design should have set the "auto" feature to come after the "headlight" setting. So it would be parking lights, headlight, then auto-headlights.
Old Feb 19, 2004 | 03:54 PM
G35MD's Avatar
I think it's a good thing, safety-wise, to have the headlights come on automatically when you enter a tunnel or parking garage.
You can have your Infiniti dealer set up to 13 different items with the control module they hook up to the car. I had it done for free with my last service.
-Now my keyfob unlock will unlock both doors with the first push, so I don't have to push twice. My wife likes to try to open the passenger door when she here's the first click, then when I push it the second time she's pulling on the handle and it doesn't unlock. That's not a problem anymore!
-Now my headlight come on sooner in "auto" mode. I found there were times before when the ambient light was low for my tastes, but the headlights stayed off. Not a problem anymore!
-Now the "auto" headlights turn off immediately after exiting and closing the door. No more problems with people telling me my headlights are on when I park in a garage!
Here's the complete list of settings your dealer can do for you.
Door Lock/Unlock (with single click on keyfob)
Mode 1: Unlock left front door only
Mode 2: Unlock all doors
Anti-lock Out (prevents locking keys in car)
Mode 1: Master door lock switch can activate door locks w/ key in ignition
Mode 2: Master door lock switch cannot activate door locks w/ key in ignition
Dome Lamp Timer
Mode 1: Interior lamp comes on when left front door is unlocked
Mode 2: Interior lamp does not come on when left front door is unlocked
Retained Power (Amount of time windows and sunroof will operate after turning off ignition)
Mode 1: 45 seconds
Mode 2: No delay (Will not operate after ignition key is turned off)
Mode 3: 2 minutes
Auto Light On (headlights turn on as it gets dark)
Mode 1: Factory setting
Mode 2: Lights come on sooner than factory setting
Mode 3: Lights come on later than factor setting
Mode 4: Lights come on later than Mode 3
Head Lamp Battery Saver (applies when headlights left in “on” position, not in “auto.”
Mode 1: Shuts lamps off after 5 minutes
Mode 2: No time delay (headlights turn off immediately)
Headlamp Illumination delay (time headlights remain on after exiting car when headlight is in the “auto” position)
Mode 1: 45 seconds
Mode 2: No Delay (lights turn off immediately)
Mode 3: 30 Seconds
Mode 4: 1 minute
Mode 5: 1 ½ minutes
Mode 6: 2 minutes
Mode 7: 2 ½ minutes
Mode 8: 3 minutes
Hazard and Horn Reminder Mode (key fob allows you to choose between modes 1 & 2, but there are 4 others)
Mode 1 (C Mode): Lock = 2 flash, 1 horn /// Unlock = 1 flash, 0 horn
Mode 2 (S Mode): Lock = 2 flash, 0 horn /// Unlock = 0 flash, 0 horn
Mode 3: Lock = 0 flash, 0 horn /// Unlock = 0 flash, 0 horn
Mode 4: Lock = 2 flash, 0 horn /// Unlock = 1 flash, 0 horn
Mode 5: Lock = 2 flash, 1 horn /// Unlock = 0 flash, 0 horn
Mode 6: Lock = 0 flash, 1 horn /// Unlock = 1 flash, 0 horn
Remote Auto Locking Function Mode (Doors automatically lock after exiting car)
Mode 1: 5 minute delay
Mode 2: Function disabled
Mode 3: 1 minute delay
Remote Panic Alarm Operation Mode (activates when button on keyfob held for approx. __)
Mode 1: .5 seconds
Mode 3: 1.5 seconds
Remote Trunk Open Operation Mode (activates when button on keyfob held for approx. __)
Mode 1: .5 seconds
Mode 3: 1.5 seconds
Remote Power Window Down Operation Mode (activates when button on keyfob held for approx. __)
Mode 1: 3 seconds
Mode 3: 5 seconds
Dr. Jim
2003 DesertPlatinum/Graphite G35C 6MT
Aero/Prem/Nav/HyperGround/XMSat/BSM/Tint/ClearBra/CG/NismoChromeShifter/RacePedals/Z-tube/JWTPopCharger
Old Feb 20, 2004 | 12:33 AM
Excellent post! I will try to go to my dealer sometime to change some of the settings. Thanks again!
Old Feb 20, 2004 | 08:21 PM
dopeymon's Avatar
i just realized that if you start your car with the lights OFF... the auto lights dont come on if you switch the lights to ON while driving... so when you get home and turn off the lights... the light does flicker on auto. The lights are auto if you leave it on auto and then start the car
Old Feb 21, 2004 | 10:11 AM
dopeymon's Avatar
i meant doesn't flicker if u started off your car as OFF then switch lights to on and when u get home turn it to OFF. The light won't flicker on AUTO
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
vamarris
Sep 26, 2015 12:56 PM
blnewt
Sep 25, 2015 01:48 PM
