Is there a really big difference in premium vs regular gas?
Old Oct 23, 2007 | 05:41 PM
  #106
g35ctuner's Avatar
maybe we should let this one die already. yeah your car could run on sake but why would you do that? just put what the people that made the car reccomend for it. whichis PREMIUM FUEL ONLY BISHES.
Old Oct 23, 2007 | 05:50 PM
  #107
SteveBlake's Avatar
The only thing premium is NEEDED for is if you are gonna redline it at every stop light. I have done research on the internet and they say if a car recommends premium you can use regular gas, it will just cause your engine to heat up more than premium but nothing too serious. They also say if you use premium and are not pushing the engine enough, the premium gas, being thicker than regular, will begin to build up in the gas tank and cause problems.
Premium Gas= Higher Combustion for better performance
Regular Gas= Lower Combustion not as good of performance
Old Oct 23, 2007 | 06:50 PM
  #108
redlude97's Avatar
Thicker, really?
Old Oct 23, 2007 | 07:17 PM
  #109
zx11pilot's Avatar
The only thing premium is NEEDED for is if you are gonna redline it at every stop light. They also say if you use premium and are not pushing the engine enough, the premium gas, being thicker than regular, will begin to build up in the gas tank and cause problems.
Compression ratio is a fixed property of your engine. It has to do with the specific bore and stroke of said engine. It doesn't change with rpm or with the type of gasoline you use.
Premium gas isn't "thicker" than regular gas. It has a higher octane/heptane percentage, that's it.
Old Oct 23, 2007 | 07:33 PM
  #110
Triple8Sol's Avatar
Nah, don't listen to any of these so-called "experts." It's all a conspiracy, concocted by "The Man."
Arco regular unleaded is the best. Just like disposable alkaline batteries, the cheapest option is always the best.
Old Oct 23, 2007 | 08:04 PM
  #111
SteveBlake's Avatar
guess those guys were a bunch of whacko's!
Old Oct 23, 2007 | 08:12 PM
  #112
zx11pilot's Avatar
Old Oct 23, 2007 | 08:17 PM
  #113
Jeff92se's Avatar
Red Card Crew
Premium has a higher viscosity for better engine protection.
Thicker, really?
Old Oct 23, 2007 | 08:55 PM
  #114
hai109's Avatar
Wow...what you can read on the internet these days...
Old Oct 23, 2007 | 09:20 PM
  #115
TroysG's Avatar
I didn't read this whole thread, well because it's 8 pages long and I've done my own research. best performance is the 94 octane (sunoco), however daily driving you lose 7% to a tank compared at 91 Octane (esso), 87 octane (both gas brands) gives you lessened performance and about 11-14% fewer kms to a tank. I did this in an 04 G35 Coupe, 03 Sentra spec-v, 06 Lexus GX470, and my dad is getting the same results so far with his 07 Harley Ultra Classic...
here's my baseline numbers for the G (so far). once I turn the car on I go directly to the fuel mileage/vaccuum gauge. it usually comes up with a number between 715km and 740km. I've only gotten over 700 a couple times and that was leisure driving. so I used 700 as my baseline. I drove consistently the same way. for 10 fuel ups - ~7000km. found that I regularly got the full 700 on Esso 91, since I started fuelling up with Sunoco I've been getting between 625 and 650 as the maximum (I had maybe 2 litres of gas left when I fueled up). I tried 87 octane at sunoco, found that the car sputtered a lil when trying to pass cars when need be, also I got about 600kms on the tank. after the sputter I decided that was enough tortune for the car.
Old Oct 23, 2007 | 09:21 PM
  #116
gurneyeagle's Avatar
Originally Posted by hai109
This thread is so funny...
You get Civics guys modding their cars and putting the best gas in their cars while a guy with a 40K car biotches and states you don't need to use the best. Regular is just good enough. Sad, if you can't afford to play then sell the car and get something you can afford.
Car is design to run at certain specs under certain conditions. The owners manual states Premium. If the car can run at a lower gas grade wouldn't the manufacture advertise that? Saves you money on gas. They don't because they rated the car's HP at a certain spec so in order to meet those HP they need the correct grade of gas.
We don't need to convince you to put a higher grade. Do what you want to do with your car. Thank god it's not my car. For all those that think its not beneficial...Just keep that comment to yourself. If you want to screw you own car then that's fine don't screw with other people's cars. For those asking go with what the manual states. Most of the stuff in the manual came from ENGINEERS that did all the RD. The retards internet mechanics that are too cheap to follow the maintenance are the last people you should be getting advice from.
Great post in the epic battle between the Taco Bell counter jockeys and the educated minority!
Just to let you know, these morons have fellow knuckle-dragging, mouth-breathing father/uncles, brother/cousins on just about every other forum for cars that burn premium.
I love the stories about the uncles who deliver gas, the friends who dilute their convenience store cheapo gas with MD20-20, or the Einsteins who spend $100 for a turbo whirl installed in their intakes raising their gas mileage by 200%.
Bottomline: anyone who frets a $0.20 difference in the price of regular versus premium has never done the math mainly because they are incapable of doing the math, yet they'll spend $100's on "mods" that do nothing but LOWER the value of their cars, thereby making them victims. It's a cirlce of stupidity.
Guys, take a few minutes, sit down with a calculator, and work these simple equations:
a. miles driven a year
b. average miles per gallon
c. gallons consumed annually = a/b
d. annual cost of using premium = c * $0.20
Now ask yourself the question - is that amount of money worth the reduced performance (both power and mpg)?
If so, get a Civic.
Class dismissed.
Old Oct 23, 2007 | 10:46 PM
  #117
bassholic's Avatar
^it's worth it
Old Oct 24, 2007 | 10:33 AM
  #118
rasetsu's Avatar
Wow. So many dilholes. The d-bags that can't justify $0.20 extra per gallon have somehow justified $40K for a car. Why not just get an Elantra? It does the same thing for $30K less. These are probably the same people who have no issues dropping $4 for a coffee at Starbucks or $5 for a beer at a bar.
I agree with the comment made above. Do whatever stupidness you want with your car, just don't go preaching it to other people.
Old Oct 24, 2007 | 04:38 PM
  #119
d_pak's Avatar
^ amen brother!!
Old Oct 24, 2007 | 07:28 PM
  #120
jalilig35's Avatar
now what is the best gas station to get gas from? one better than the other, any recommendations? i live in southern cali
