Brakes & Tires
Old Nov 3, 2007 | 10:12 PM
Mikalvelix17's Avatar
Brakes & Tires
i own a 2005 g35 6mt and am in need of new brakes and tires. should i stick to OEM brakes? if so, what brand is it? about the tires, what do y'all recommend? i hear falken fk 542s are pretty good. please list a few top-rated AFFORDABLE tires (preferably ones with little road noise & comfort).
Old Nov 3, 2007 | 10:17 PM
DrrSeuss's Avatar
There are separate sections on this forum just for brakes and tires. There are plenty of threads on pads and tires.
Oem brakes are fine so are Hawk pads. I have FK 452s and I love em.
Old Nov 3, 2007 | 10:35 PM
Joaquin03's Avatar
Staff ALUMNI
hawk pads FTW.. and tires are always a toss up, but 452's are always good.. so are Toyo Proxes T1R's for performance... Michelin PS2's aren't too bad either.. hmmm.. I run Proxes4 and don't have any complaints
Old Nov 3, 2007 | 10:45 PM
thanks guys, keep em coming... as for now i guess i can put the brakes on hold given that it hasn't been giving me any problems in terms of noise and braking; it just looks a bit thin. however; tires are something i should really look into and so far my eyes are on the falken fk452s.
Old Nov 3, 2007 | 11:32 PM
dan|el's Avatar
+1 for Hawk pads.
+1 for Toyo Proxes T1R's.
Old Nov 4, 2007 | 09:33 AM
griff87e's Avatar
bfg g-force all the way, best tires i ever bought, fit on the stock 19's
Old Nov 4, 2007 | 09:40 AM
snavematt's Avatar
just a sedan
hawks a must, almost zero dust compared to OEMs, Also Falkens are nice, quiter than my Bridgestone that are on my OEM 17s
Old Nov 4, 2007 | 08:33 PM
G35fromPA's Avatar
Hawks dust less, true, but don't bite as well as OEM pads do, especially if you live in northern climates where temps drop below 45 and it rains.
Old Nov 4, 2007 | 08:49 PM
snavematt's Avatar
just a sedan
mine have been fine so far, will have to see what happens this winter. Still have the OEMs pads may go back to them for the winter with the 17s. Just hated cleaning the chrome on the 20's every other day with the OEMs
Old Nov 5, 2007 | 08:19 AM
gto2050's Avatar
Check out the Yokohama AVS ES100's from Tire Rack. Good price, agressive looking tire, much better than Michelin PS2's, and a dang good tire.
Old Nov 5, 2007 | 11:40 AM
SukaZenki's Avatar
+1 I've been running the same set since I've replaced my stock. Talk about GRIP; these babies not only look so aggressive from a stand still and perform aggressive in even in hard wet surface. Another plus is it's thicker in threads to some of the other ones I've checked out thus you've got more rubber to burn specially on a G35 that's RWD. The flame out design on the threads when you look from the rear just makes the G look so good. Price on the other hand, if you can afford the G - then you should be able to afford the right shoes. My 2 cents.
Old Nov 5, 2007 | 02:42 PM
krazygluee's Avatar
idk...but i got BREMBO brakes
Old Nov 5, 2007 | 02:56 PM
gto2050's Avatar
Me too....30,000 miles and not even half worn.
Old Nov 5, 2007 | 03:17 PM
krazygluee's Avatar
my car has 40,000 miles when am i sposed to replace them
Old Nov 5, 2007 | 04:33 PM
UMBG35's Avatar
I just changed my brake pads 2 days ago with OEMs. It's a 2005 G35 5AT with 43K. The rears were low (enough to make the annoying indicator touch the rotors) but the front pads had still 50% left, to my surprise. There is a great DIY for brakes on this forum, I'd highly recommend it. I've never changed pads in my life mostly because I was worried since it's such a vital component and possibly hazardous if done improperly but it took me 20 minutes for both rear pads. It's practically, impossible to screw up. There is one screw to loosen in the rear and two in the front and that's all...I think it's easier than an oil change but a tad harder than changing the air filter
P.S. I didn't get my rotors turned since there is no indication that it's warped. I put 1000 miles since changing the pads, no noise, no problems.
derres
Aug 28, 2015 03:27 PM
linedr89
Aug 17, 2015 05:11 PM
Srinidhi
Aug 7, 2015 03:38 PM
wuppiedog
Aug 7, 2015 11:16 AM
mushu
Jul 15, 2015 03:55 PM
