smell after aggressive driving
Old Nov 22, 2007 | 07:55 PM
O HELLA OEM's Avatar
i have the same problem..hmm
Old Nov 23, 2007 | 02:57 AM
Goonar's Avatar
Geee Man
i have the same thing.....its only when i floor it tho. but i desperately need an oil change..so if there is a correlation ill let you know when i get it changed..
Old Nov 23, 2007 | 07:28 AM
Triple8Sol's Avatar
Did you eat Mexican food beforehand?
Old Nov 23, 2007 | 08:25 AM
chilibowl's Avatar
I think the VQ35 just likes to 'flatulate' when you beat on her.
Old Nov 23, 2007 | 01:35 PM
sliderg35's Avatar
I don't smell anything... But the car is so fast now, it probably takes 5 minutes for the smell to catch up.
Old Nov 23, 2007 | 02:23 PM
M@rCo's Avatar
I have had the same smell since I got the car with ~30k miles.
I know its not due to needing an oil change because it happens ALL the time when going WOT.
It was worse before I put in my K&N...I was thinking it was from the dirty filter....guess not though...
doesnt seem like something to worry about
Old Nov 24, 2007 | 01:45 AM
d_pak's Avatar
Same thing here, '07 6MT with 4500 miles, notice it when I take off quickly, or accelerate quickly touching 5+k rpm in each gear. It smells like burning rubber. I will try it tomorrow again, pull over and pop the hood to see if I can isolate it.
Don't think it is the brakes or clutch. Bizzare!
Old Nov 24, 2007 | 03:05 PM
Canadian's Avatar
Canada, eh?
Originally Posted by Nismo G
Its your oil temperature i think...after i floor the car about 6 times from 0-80mph+ i start to smell that burning smell as well. Sometimes if im lucky the engine will get over heated and smoke starts comming from the hood. Then you take her easy for the next 20 min
-Sean
Damn, yours actually overheats? I just got back from the track last weekend and it got hot, but it never overheated to the point where smoke was coming out of the hood. Thats with 3 30-100 runs in 1 lap and like 15 laps...and I'm on stock cooling.
And no, I didn't get any weird smells or anything, just the brakes.
Old Nov 25, 2007 | 01:25 AM
pantablo's Avatar
I've been recently noticing this same thing. Weird thing is that it definitely smells like burning oil and I get it more from the rear of the car than the engine area. And its when I run 5-6+k revs for short time (I drive lots of short trips).
Mine is also an 07 6mt with about 4500 miles on it and I've had the first oil change already. I figured my car was burning oil...
Old Nov 26, 2007 | 01:17 PM
chilibowl's Avatar
Check your oil homie, your car may be more than likely burning oil. Im starting an oil consumption test with my local dealer.
Old Nov 26, 2007 | 01:21 PM
Nismo G's Avatar
I don't think it overheats...im not sure. The temp guage stays with in one click, but when i stop you can smell burning and you will see a little 9almost none)smoke come out from under the hood...im still on the factory coolant (107K miles).
-Sean
Old Nov 26, 2007 | 02:37 PM
Glycerine's Avatar
Check your cats for plastic grocery bag residue :P
https://g35driver.com/forums/g-spot/120157-beware-plastic-bags.html
Old Mar 15, 2008 | 05:25 PM
_Frank Starks_'s Avatar
I know this is an older thread but has anyone discovered anything new about this? My coupe's having the same smell.
Old Mar 15, 2008 | 05:39 PM
425skyline's Avatar
i have always thought it's just the tires.. it's the same smell if you do a burnout or some doughnuts
Old Mar 15, 2008 | 05:45 PM
  #30
I'm reading about a lot of the same symptoms caused by the aggressive driving. There's a lot of people acknowledging this issue but has anyone found a resolution?
I like driving my G aggressively...
