No airbag.. should I get a harness for safety?
Old Jan 8, 2008 | 09:08 AM
nycityinsomniac's Avatar
wow redlude id do you if i was gay. that was a great response
Old Jan 8, 2008 | 11:08 AM
solopresident's Avatar
teamsolo.net im-integline
ty.
Old Jan 8, 2008 | 01:34 PM
in2win's Avatar
Take the money you would spend on harnesses and buy a used airbag. Ive seen them go for 600. That would be your best bet. A roll cage, plus harnesses, plus padding, plus a high ife insurance policy equals mucho $$$$.
Old Jan 8, 2008 | 02:58 PM
redlude97's Avatar
His problem is he swapped to an aftermarket steering wheel, not that he doesn't have the airbag on the stock wheel
Old Jan 8, 2008 | 06:17 PM
Jason@Riverside's Avatar
You do not want a harness unless you have a full roll bar / cage... and wear a helmet with the neck brace / head strap that holds your head back against the seat instead of going forward...
The harness will keep you sitting straight up, wont let your upper body move, but your head will go forward...
the harness will also keep you sitting straight up in the even you do flip, your body will not lean to the side (like it will with a 3 point) and your head will be crushed in by the roof top / ground...
Best thing to do is to sit further back from the wheel...
Old Jan 8, 2008 | 07:22 PM
in2win's Avatar
ahhh my memory is slipping...thank you
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
the93owner
Sep 28, 2015 10:37 PM
vamarris
Sep 26, 2015 12:56 PM
AuAltima3.5
Sep 13, 2015 11:48 AM
