why do lights flash twice when i lock the car?
on
Originally Posted by 97prelude
hey guys, before you flame me, i searched like a ****.
Anyway, my car's lights used to only flash once when i locked the car, now the flash twice, any reason why?
To reprogram:
- Hold down both the lock and unlock buttons on the key fob at the same time for about 10 seconds.
- Then release
Now try unlocking and locking your vehicle. You will now notice that when locking there is no flashing and horn, and when you unlock the lights just flash once or twice. If you don't like that setup you can always revert to the previous setup by performing the same programming.
my accord is the opposite, flashes twice for unlock and once for lock, with no horn unless you push lock a second time.
i like the g's setup better, except i wish the horn was an electronic beep.
i know there is a mod from kptech for this, but they really should have just made it like that from the start
i just reprogram mine today... i wanted the lock lights to flash twice (no horn) and unlock one flash (no horn) but i can't get it to work that way.
it's either
Lock : two flash (no horn)
unlock: does nothing
lock: two flash (horn blow)
unlock: 1 flash (no horn)
it's either
it's either
it's either
Thanks!
Originally Posted by G-Fusion
g's tend to lock 2wice cuz of the locking the doors that one blink the 2nd blink for set up alarm ...the unlocking mode is 1 blink is to unlock all .. that is my thoughts...
The blinks are simply what has previously been described in this thread.
aren't there 2 more settings hidden that CONSULT-II can access?
IIRC, you can use CONSULT-II to program it to flash twice (lock/flash once(unlock).
EDIT, there are actually 4 other settings that can only be accessed with CONSULT-II
Hazard and Horn Reminder Mode (key fob allows you to choose between modes 1 & 2, but there are 4 others)
Mode 1 (C Mode): Lock = 2 flash, 1 horn /// Unlock = 1 flash, 0 horn
Mode 2 (S Mode): Lock = 2 flash, 0 horn /// Unlock = 0 flash, 0 horn
Mode 3: Lock = 0 flash, 0 horn /// Unlock = 0 flash, 0 horn
Mode 4: Lock = 2 flash, 0 horn /// Unlock = 1 flash, 0 horn
Mode 5: Lock = 2 flash, 1 horn /// Unlock = 0 flash, 0 horn
Mode 6: Lock = 0 flash, 1 horn /// Unlock = 1 flash, 0 horn
Can you explain to me what CONSULT-II and IIRC are? (Too lazy to search right now.) Also, if those modes are available, are they accessible (can the code be "cracked") without the KPTechnologies mod?
