Squeaking Noises coming from the Outside Rear
Old Mar 14, 2004 | 11:51 PM
RidinThaGSpot's Avatar
What could it be? I thought it was the wheels or something, but when i told the dealer about the noise i heard, they said they checked the clutch and said it was fine. What is that noise i'm hearing. It's sorta a squeaking or rubbing noise, that i hear at random times. Clutch down or up.
2004 Infiniti G35 Coupe 6MT - Premium ]| Aero |[ Bose ]| Z-Tube |[
2003.5 Infiniti G35 Sedan 5AT - Premium ]| AeroKit |[ Spoiler ]|
Best of both worlds
Old Mar 16, 2004 | 02:20 PM
Re: Squeaking Noises coming from the Outside Rear
so i'm guessing nobody knows what it is.
Best of both worlds
Old Mar 16, 2004 | 02:57 PM
Msedanman's Avatar
O.F. Administrator
It'll be one of the links at the rear, probably springs, shocks, or sway bar.
If it's cold where you are, then some water has seeped in and has frozen.
Could also be a dry bushing on the sway bar.
Your dealer should be familiar with issues like that.
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old Mar 16, 2004 | 08:36 PM
BIGAPPLEVIP's Avatar
THOSE SQUEAKING NOISES ARE THE LITTLE GREMLINS WITH THE HAMMERS ON THE OUT SIDE OF YOUR CAR. (JUST LIKE IN THE BUGS BUNNY CARTOONS )
MY LOCAL INFINITI MECHANIC HELPED GET RID OF THE LITTLE *** MONGERS
AKA SET ROK
Old Mar 17, 2004 | 12:03 AM
it is cold here (nj) but at the time of the squeaking, it was pretty nice for a constant amount of time. BTW.. the squeaking, while not as consistant, is becoming louder.
Best of both worlds
Old Mar 17, 2004 | 05:14 PM
I HAD THE SAME PROBLEM. LET ME GUESS IT ONLY HAPPENS WHEN YOU GO OVER A COUPLE OF BUMPS AT A TIME AND SOUND LIKE YOUR RAILING SOMEONE IN A BED. AT INFINITI THE MECHANIC SAID IT HAD TO DO WITH SOMETHING BY THE GAS TANK THEY FIXED IT IN UNDER A DAY
AKA SET ROK
Old Mar 18, 2004 | 02:59 PM
TheDudeG4's Avatar
interesting, I just noticed the same noise
...off to the dealer I go
'04 Coupe 5AT BS | Premium | NAV | 18" Wheels | Borla Exhaust | Aluminum Pedals | Clear Corners |
Old Mar 18, 2004 | 05:14 PM
SickG35's Avatar
I'm having the same problem too. My car is just 700 miles and I had my springs installed in the first day I got the car, so I didn't have the chance to check for the noise before i got springs installed. I had a 5AT before with the same Tein Springs on it and didn't have no noise. It's irritating cause it's hard to know where it's coming from. I just hear it when I'm starting to drive on first gear and I give a little punch or go very low on the rpm's and press on the gas.
04 G35C 6MT/Navi/Z-T/JWT/Tein S/Volks GT-7/CC
Old Mar 19, 2004 | 07:43 PM
WhiteWarlock's Avatar
At 7,000 miles, I took my '04 coupe in for a problem with a squeak coming from the rear. I noticed that the squeak would stop if I touched (any amount of pressure) the brake pedal. Well, they said it was probably brake dust and that they cleaned it.
I paid for a 7,500 service that I had done at the same time (which included brake inspection).
However, not two weeks latter I noticed it again. Then I realized, I notice it when:
(1) I drive with the radio down or off (as I do when my wife is with me).
(2) I drive with a lot of stopping/going (read: use the brakes more than I do on an open highway).
Well, I took it in again. They said the rear brake pads (Brembos) were glazed. They replaced them under warrantee.
So far, I think it's fixed. But, my question is "Why/How did they get that way?" I don't drive with my foot on the brake. I didn't do any hard braking when I was breaking in the car. I'm wondering if the rotors are warped either as a result or as a cause of the glazed brakes (which apparently were rubbing when they got hot).
My advise, get your rear brakes checked.
Old Mar 23, 2004 | 03:11 PM
TheDudeG4's Avatar
im not so sure we are talking about the same problem then. I dont have the brembo brakes, but I hear the same noise. I'm just wondering if anyone had any more info on the gas tank issue, I think that seems more like it fits my description of the problem.. I want to know what to tell the service tech when I bring the car in to have them look at it.
'04 Coupe 5AT BS | Premium | NAV | 18" Wheels | Borla Exhaust | 350Z Tube | TechnosECU | JWT Pop Charger | Stillen Grounding Kit | Aluminum Pedals | Clear Corners | 15% Centaur Tint
Old Mar 23, 2004 | 04:34 PM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
I have the same issue. It almost sounds like leather rubbing up against itself, huh? Let me know what you find out.
2 G or NOT 2 G, there is no question!
'04 Coupe 6MT: DG on BLK, Prem, Sport, Nav, Custom Tint, K&N Intake/Filter, Gordgee's Grounding Gear SOON!
--License Plate: RANDYS G...say HI if you see me!
rezendvous420
May 31, 2020 01:26 PM
atk08
Jul 30, 2015 03:12 PM
rping
Jul 26, 2015 09:53 PM
ddietz97
Jul 26, 2015 06:16 PM
