Exhaust tip cleaning...
Old Mar 23, 2004 | 01:39 PM
XCELR8's Avatar
What's the best cleaner for the stock exhaust tips? Been a nasty winter and they got sort of dull and have some black carbon around the edge. Any tips (no pun intended) would be great!
2003 BLK/BLK 6-spd Injen clear corners
Old Mar 23, 2004 | 02:25 PM
NismoCPV35's Avatar
Re: Exhaust tip cleaning...
I use Meguiar's Gold Class Wheel Cleaner. It works great on my Bronze Nismo LM GT-4s and my exhaust tips. It makes the exhaust tips look brand new inside and out. Just make sure you don't use solid stream to rinse the inside area to prevent water from getting into the muffler -this could lead to corrosion.
SKYLINE 350GT, NISMO R-Tune.
Old Mar 23, 2004 | 03:56 PM
cryhavok's Avatar
Pick up a little can of Meguiars Mag & Aluminium polish. It'll make them shine like a mirror!
Old Mar 23, 2004 | 05:51 PM
Meatshackle's Avatar
Deep Sea Moderator
NismoCPV35's tips look brand new inside and out. After seeing his I'm going to start using that as well.
Russ
Black 6MT Coupe
Jax, FL
PS2 and Headrest Monitors Thread
Old Mar 23, 2004 | 06:00 PM
avs007's Avatar
To clean the black stuff off the inside of the tip, others have recommended chimney soot cleaner. Seriously... I forget the name of the product, I can look it up if necessary. Basically, they said its this liquid that you normaly use to clean your fireplace. It removes the black stuff really easily without any rubbing or scrubbing.
Old Mar 23, 2004 | 07:09 PM
rwjcp721's Avatar
Try Wenol Metal Polish 1 and 2 (made by a German company if I remember correctly). I bought some from www.properautocare.com and it was great for getting the carbon build-up off my tips. The #1 polish (Wenol Red) cuts right through the carbon crap, and the #2 (Wenol Blue) really makes the tips shine. It's only like $15 for both if I remember right, and they last forever cause a little bit of it goes a long way. I highly recommend!
2003.5 G35 Coupe 6MT Black/Willow
- Texas Tech Mechanical Engineering -
- Texas Tech Advanced Vehicle Engineering -
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
