Help!!! Battery Keeps Dying
Old Mar 4, 2008 | 05:10 PM
2004v35's Avatar
Like The Title Says I Have My Coupe For About Two Years Now And Within The Last 6 Months My Battery Has Died On Me Twice And Dont Have Any Ideas Why
Old Mar 4, 2008 | 05:13 PM
Dakkerz's Avatar
Get the battery and alternator checked.
Old Mar 4, 2008 | 05:14 PM
Johnmikins's Avatar
Is this a daily driver??? Crazy sound system???
Old Mar 4, 2008 | 05:23 PM
crashnburn's Avatar
bad starter.... sounds weird but mine did it for like a year, ten it got bad enough i had to get jumped off everytime....so i changed the battery, checked alt, and still same ****...but then i changed the starter and problem went away
Old Mar 5, 2008 | 01:34 AM
Roguewolf's Avatar
get a new one ;D
Old Mar 5, 2008 | 12:09 PM
2004v35's Avatar
the battery is new maybe two months old if that and dealer checked starter and alt first time it happen and told me there was nothing wrong with them
and yeah its a daily driver but only 5 miles a day
Old Mar 5, 2008 | 02:05 PM
g35rcr's Avatar
do you have any aftermarket stereo eq? if so make sure you have it wired to acc to turn on and not a constant
Old Mar 6, 2008 | 02:55 PM
05GCOUPE6MT's Avatar
Start by making shore the Battery Terminals are clean and tight.
Old Mar 6, 2008 | 03:52 PM
JessNherG's Avatar
I can't help you, but if i leave my radio on(alt) after shutting the car down my battery will die.
In my case i think i need a new battery, but i am fine being surprised that my car starts everyday
Old Mar 6, 2008 | 10:52 PM
g35pat's Avatar
My car is garaged and when I first got the car, I've drained my battery on a few occasions by leaving my keys in the ignition (even if in the off position)...
Old Mar 6, 2008 | 11:30 PM
hitthemark41's Avatar
Cool May be a short in the radio....
I had the same problem (I have a 2003 G35 6MT Coupe)...battery died in 2007 so I had it replaced (DieHard from Sears). However it died again maybe a few weeks later. Both times the car had been in the garage and undriven for a few days or a week. When it died again I took it to the Infiniti dealer and found that it had a parasitic draw in the radio system. If was replaced (incorrectly the first time..apparently Infiniti doesn't know that the sedan and coupe use different mother boards..go figure!) One last note...the battery from Sears was a dud as well...so had to replace that TOO...so your best bet is to just let Infiniti replace the battery if need be...a few extra pennies are always worth the peace of mind
Old Mar 7, 2008 | 05:04 PM
2004v35's Avatar
thanks for all the feed back took it to infiniti and there looking into the problem right now
KruZZe
Feb 27, 2023 05:04 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Thebaws11
Nov 30, 2016 12:54 PM
g.spot
May 9, 2016 10:54 PM
dcsbh1
Oct 1, 2015 03:15 PM
