ok guys: ABS light, VDC off and slip lights on and ABS actuator going crazy
Old Dec 2, 2008 | 04:44 PM
crashnburn's Avatar
i got the abs vdc and slip light today just now.... i had a scanner on me and i got code p1108 and it said left front speed sensor erratic.. then drove another 2 miles and it went off.... i did feell the abs in the pedal right b4 it cam on and did again with the lights off
Old Jan 7, 2009 | 06:10 PM
Westy07's Avatar
2006 g35
I have the same problem with the ABS actuator running after turning the car off. Is there a way to disable the ABS system by pulling a fuse or relay rather than disconnecting battery?
Mry
Mar 3, 2023 01:03 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
JermaineSanders
Aug 18, 2015 08:57 PM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
