My Car goes into slip on alot more often then normal. Is there anything i should check to fix this problem. Maybe sensors?
The ground is dry. So now i press the vcd everything time i get and it doesn't the light does come as much. It is just scary when the abs or what ever you call it the pulsing to the brake when i am in perfect control of my car.
Help any one
Also is there a solution or switch to turn off everything even when the button says it is off
Help any one
You can pull the VDC fuse to totally disable the sensor which I know is done for track use but I wouldn't recommend for the street.
Help any one
Originally Posted by specialist
My Car goes into slip on alot more often then normal. Is there anything i should check to fix this problem. Maybe sensors?The ground is dry. So now i press the vcd everything time i get and it doesn't the light does come as much. It is just scary when the abs or what ever you call it the pulsing to the brake when i am in perfect control of my car.
Help any one
Couple of things could cause this. Do you have non micheln pilot sports on the car? That can cause it for the first few thousand miles of the tires life. Also your brake fluid could be low causing the slip light and stuff to freak out.
These are minor causes but worth the shot to throw those out.
my slip light comes on as well with the VDC off. Not sure if its a bad thing...then again im in seattle too.
That is definitly your barke fluid being to low and it is sloshing around in the resevoir. Check the level and then let us know.
Fluid is all the way up. May be it is tires that i got. I got toyo winter. maybe they are griping to much and the slightes movement in them the sliplight comes on? What do you think?
