tire pressure sensor light?
Old Apr 26, 2008 | 09:12 AM
2fast's Avatar
Hey guys,
I have an 06 coupe and aftermarket rims/tires that dont have any tire pressure sensor..
The light on my dashboard that shows low tire pressure is very annoying.. Anyway to remove it?
Old Apr 26, 2008 | 10:11 AM
jzhu625's Avatar
search is your friend
Old Apr 26, 2008 | 12:00 PM
LjN_728's Avatar
From what I know, the only way you can disable the TPMS is by it's fuse. First of all, nobody seems to know where it is, and second, I'm sure there are other things besides TPMS that specific fuse is responsible for. Either you put a piece of tape in front of the light so you don't see it anymore or you buy a set of sensors and put it in the aftermarket rims.
Old Apr 26, 2008 | 01:20 PM
06PlatinumG's Avatar
I believe it's illegal to disable the the light even if you can figure it out. Why don't you just move the sensors from your stock wheels to your aftermarket ones?
Old Apr 26, 2008 | 06:21 PM
08G37TX's Avatar
I have a single TPMS sensor I would sell you if you needed it.
Old Apr 26, 2008 | 06:32 PM
gary c's Avatar
Not installing TPS on after market wheels....?
Bump for stupidity....
Old Apr 26, 2008 | 06:39 PM
XBrisk202's Avatar
i'm bumping again because i'm stupid
I just threw rims on my car for the first time and my light came on too. Does that mean all aftermarket rim owners just leave theirs on/already have tire pressure sensors on their rims? How much does it cost to add those? I'm stupid
Old Apr 28, 2008 | 01:58 PM
2fast's Avatar
my wheels dont fit TPM conventionally.
i think i need to use the tape method?? I just think its too much stress, i check my tire pressure daily it takes 1min
Old Apr 28, 2008 | 04:00 PM
Memphis's Avatar
Actually, tape is NOT an option, unless you are using tape over the light on the dash..... .....however there are a couple of true options.....
1) First Option uses a bracket and a regular valve stem to clamp the TPMS to the rim with a conventional valve stem
2) Second Option uses a strap around the inner circumference of the rim to hold the TPMS.
I've used both....the strap method is the easiest to get a tire shop to use because the bracket isn't readily available.
Muski_G
Dec 1, 2023 11:11 AM
ghost_g35
Aug 7, 2015 10:31 AM
igking
Jul 19, 2015 01:12 AM
Jadenkid22
Jul 14, 2015 12:33 AM
