TPMS reset
Old May 12, 2008 | 01:14 AM
cb4h's Avatar
TPMS reset
Ok just picked up an 06 G35 coupe yesterday has all the options except the nav system. My only question is the Tire Pressure system has come on and I was wondering how to turn it off. I put air in all the tires and i know on my 525 bmw i can reset the system using the idrive system. I was wondering how to do this on the infiniti? Thanks
Old May 12, 2008 | 09:31 AM
BlueDevilBAMF's Avatar
Couple of possibilities:
(1) You have aftermarket rims without TPMS, so the light will always be on unless you get a set of sensors and have them programmed by an Infiniti dealership.
(2) You have stock rims that someone took TPMS out of - if the valve stem on the stock rims is rubber, there is no TPMS. If it's all silver, it's probably TPMS.
(3) You have rims that do have TPMS, but the TPMS hasn't been programmed to your car. In this case, you can swing by an Infiniti dealership and have them programmed.
Unfortunately the only way to "reset" the TPMS per se is to turn off the car. However, once you drive a bit, the light will flash and then stay solid. Some people have put a piece of tape over the light, or just learned to live with it.
I'd personally pick up a set of TPMS if you don't have them. They often go for ~$100 for a used set here on the boards. To me, the cost of buying a used set of TPMS, paying for another mounting/balancing and TPMS programming is worth it to get rid of the light and have TPMS working.
Old May 12, 2008 | 10:09 AM
rasetsu's Avatar
Or 4th possibility: TPMS is malfunctioning/bad sensor like on my wife's. The system is crap especially for those of us without nav. The nav displays which wheel is low or faulting.
Old May 12, 2008 | 01:34 PM
cb4h's Avatar
i do have the TPM and i think it may be a malfunction or maybe just needs reprogramming. Maybe i will just swing by the dealer and see. Thanks for the replies tho guys I appreciate it.
Tyler
Old May 12, 2008 | 02:39 PM
Texasscout's Avatar
I have M-45 sport rims on my sedan and the TPM work around town just fine. However, if you get on the highway and cruise for more than 45 min, they come on and stay on.
Old May 12, 2008 | 07:48 PM
cb4h's Avatar
thanks for all the replies. I ran it by the local Nissan place, didnt have an hour to drive to infiniti. They said it was a bad sensor but couldnt fix it because they wont cover warranty work. So i made an appointment for friday at Infiniti
Old May 12, 2008 | 09:29 PM
Hopefully it's not too much to fix... If you need a whole new one from the dealer it's pretty expensive.
Old May 12, 2008 | 10:00 PM
cb4h's Avatar
i hope its covered under warranty the car only has 13k miles on it. So hopefully they will take pity and fix it for nothing lol
Old May 12, 2008 | 11:01 PM
^ Good point, should be covered under bumper-to-bumper warranty.
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
vamarris
Sep 26, 2015 12:56 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
