350Z Suspension
Old Apr 15, 2004 | 06:15 PM
GPhanatic's Avatar
350Z Suspension
Has anyone tried the 350z suspension on their coupe? If so, how does it ride and its handling. Any feedback would be appreciated. Peace.
Old Apr 16, 2004 | 12:17 AM
StudlyMobile's Avatar
Re: 350Z Suspension
wouldn't it be the same?
i know the 350 has different packages, not sure the varieties.
04 6mtC, DG - possibly most babied G on the board.
Old Apr 16, 2004 | 01:02 AM
DragonGcoupe's Avatar
Re: 350Z Suspension
The 350z has stiffer springs I think.
Black / Black 2004 GcoupeMT. Premium. Splash Guardz.
Old Apr 16, 2004 | 01:20 AM
GPhanatic's Avatar
Re: 350Z Suspension
Is the Z height lower than the G? Will this lower the car if I put it on?
Old Apr 16, 2004 | 02:05 AM
Re: 350Z Suspension
Iono about the springs, but the car is lower I believe.
Old Apr 16, 2004 | 08:59 AM
SkyLine350GTs's Avatar
Re: 350Z Suspension
I dont think the 350z springs/struts will lower the coupe at all. The z springs are just stiffer, and the struts are more agressive.
Go drive a 350z and that will tell you how the G drives w/ the Z springs and struts.
I really recomend this mod, it definitly makes a night and day difference over the stock sport suspension.
make shure u get the springs/struts off an 04 350z w/ a build date after 11/30/04.
High Point, NC
04 G35 6MT Sedan, Diamond Graphite on Black.
Arrived on 10/20/03
AIM: OneFast4Door G35
Old Apr 16, 2004 | 09:14 AM
Daniel_G's Avatar
Re: 350Z Suspension
Actually this brings up a question I've been curious about but haven't had a chance to jack up my car and take a look.....do we also have a carbon fiber drive shaft like the Z?
Old Apr 16, 2004 | 09:20 AM
Re: 350Z Suspension
No, no cf driveshaft, plus on the z the drive shaft is just renforced w/ cf.
High Point, NC
Arrived on 10/20/03
Old Apr 16, 2004 | 11:35 PM
Gsedan35's Avatar
Re: 350Z Suspension
350Z springs are the same as on the coupe, same height too. Where the difference lies is in the valving on the shocks, with the Z getting much more aggressive valving. A couple of Z owners have put on Couple shocks to lesson the bounce they have with the oem Z shocks. Only trade off is the car's abilities are toned down to with the milder shocks. The sedan is the model that has taller springs, though the sport model has the same spring rates as the Z and G coupe since it's springs are taller, the rates to quite equate the same when compressed in travel. Non sport sedan's use about 10% softer springs and softer still shocks (much softer IMO).
I have the 350Z suspension on my sedan. The performance is much better than the oem setup, improved in several key areas. But thank god for that, if the roads less then smooth, it get quite a bit of bounce. If the handling was so much better and I got the setup for a song. I would have pulled the Z suspension off the car a long long time ago. I'm waiting for Tokico D-spec double adjustable shocks to fix the bounce and give even better performance.
"All that's necessary for the forces of evil to win in the world is for enough good men to do nothing.”
Edmund Burke
G35 6mt
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
DRG35R
Jan 31, 2016 07:14 AM
Patrick Bovee
Oct 1, 2015 10:42 AM
