Trunk not opening
Old Apr 15, 2004 | 07:28 PM
rieskame's Avatar
Trunk not opening
Every once in a while my G will not let me into the trunk. Doesnt matter if I hit the key fob or the button on the console, the trunk will not open. Unless I am blind, there isnt a keyhole to open the trunk from outside without the keyfob. When this happens, it usually is in gear with the parking brake on. If i turn the car back on, the trunk usually works or I have to get to the trunk through the rear seats. On a normal day, it takes about 3 or 4 pushes on the keyfob for it to open. The cannot be normal. Does anybody else have this condition? I looked through the manual to see if there was any hints, but found nothing.
Eric
Old Apr 15, 2004 | 09:02 PM
DHCrocks's Avatar
Re: Trunk not opening
as far as the key fob, you need to hold it down for a second or two before it pops, just a safety thing so you don't accidentally open the trunk if you press the button by mistake. no key for the trunk. have no idea about the dash button though.
Old Apr 16, 2004 | 12:06 AM
MyGUnit's Avatar
there's a switch in your glovebox, on the left hand side..try that
Mitch
2004 G35C AT
Blk/Blk
Prem.Aero.Perf.Nav
Nav/TV Tuner w/ PS 2
2-10" Subs w/ Rockford Amp
Clear Corners
Pop Charger
Z-Tube
Old Apr 16, 2004 | 03:20 AM
Msedanman's Avatar
O.F. Administrator
Sounds like the unlock mechanism in the trunk needs some adjustment. Maybe the lid is too tight when closed thereby not allowing the lock to activate easily.
Dealer time if it persists.
<font color=red>GSM</font color=red>
<font color=black>Silverstone Coupe</font color=black>
Old Apr 16, 2004 | 01:01 PM
rieskame's Avatar
just checked the switch, it is on. It seems to work better if I hold down the button, but that doesnt explain why sometimes I am completely locked out from the trunk.
Old Apr 16, 2004 | 03:43 PM
Msedanman's Avatar
O.F. Administrator
Yes it definitely sounds like an intermitent connection. The dealer will have to look at it. G/L. [img]/w3timages/icons/smile.gif[/img]
Old Apr 16, 2004 | 05:31 PM
DragonGcoupe's Avatar
Hey .. I'm glad someone had the same problem as me. It's happened twice now. I can't open the trunk from the key fob. I can't open the trunk from the switch. And I know the button in the glove compartment is on. I had to start the car to get it to work.
Black / Black 2004 GcoupeMT. Premium. Splash Guardz.
Old Apr 16, 2004 | 10:48 PM
StudlyMobile's Avatar
dhcrocks
i didn't know you had to hold it down. i always just thought the fob was weak
04 6mtC, DG - possibly most babied G on the board.
Old Aug 9, 2004 | 09:19 PM
this happened to me other day. tried holding fob in, no. tried regular release, no. tried glove switch, no. i think i then turned on power and tried glove on/off then it worked.
Old Feb 3, 2005 | 10:04 PM
rieskame's Avatar
anybody have a fix on this yet?
Old Feb 5, 2005 | 12:04 PM
g35junky's Avatar
Man tha is funny. I had the exact thing happen to me this morning. Went to open the trunk and nothing. Had to turn the ignition on and then pop the trunk. Weird.
Old Feb 5, 2005 | 05:18 PM
GonSpeed's Avatar
if it is in gear, the trunk wont open. Is it like that incase your driving and u bump the button, the trunk wont open, and everything fly out.
Old Feb 7, 2005 | 10:48 AM
ryanm's Avatar
my trunk always opens while in gear. I park the car in gear always. If I go to the grocery I always open the trunk first to put the groceries away, always while in gear, and have never had any problems... don't think it has anything to do with being in gear.
Old Jul 16, 2005 | 04:10 PM
Wayno_san's Avatar
20 Year Member
I have a 2005 6mt and I also have intermittent issues with the truck not opening with either the key fob or the trunk release button next to the VSC. Cycling the ignition key re-enables the trunk release. Does anyone know if there is a fix? I've looked through a few threads and I haven't found one that tells of a resolution.
Thanks,
Wayno-san
Old Jul 16, 2005 | 04:28 PM
3Aims's Avatar
same problem here.
