Just installed sways - front clunking
Old Jun 9, 2008 | 02:25 PM
Mr Inkredibul's Avatar
I had a shop install my Progress Sways with Polyurethane bushings. Less than 15 miles later and the front clunks over small bumps.
Anyone know what might be the issue?
Old Jun 9, 2008 | 02:50 PM
falconey's Avatar
Could be a loose sway bar. Take it back and put it on the lift.
Old Jun 9, 2008 | 03:11 PM
Boston's Avatar
Had the issue after installing my Stillen sways. I ended up with a snapped end link. The original OEM links on the 03's were pretty weak IMO. Revised OEM links are available and what I used to replace my originals.
Old Jun 9, 2008 | 03:17 PM
I replaced all four of my endlinks with OEM endlinks from everythinginfiniti.com. Would they have sent me the revised endlinks?
Old Jun 10, 2008 | 12:17 AM
Everything looked good and was really tight. They didn't check the collars tho....could that be it?
Old Jun 13, 2008 | 03:55 AM
425skyline's Avatar
1) check to see if there is some kind of collar system to hold the bar from sliding sideways; if there isn't, get some collars or get the revised versions of the sway bars for our cars with welded collars
2) if you are lowered, i would recommend some aftermarket end links like the adjustable PowerGrid ones from Z1 performance
3) make sure to grease them up real well; mine "clunk" and "creak" all the time after some time has passed w/o grease. I've treid a lot of lubes and they all wear out. Right now I am using this teflon spray grease and just soak the bushings and bar in that crap while i'm under the car. It stays quiet for a month or so and then I gotta do it again. other lubes have lasted me about 2 weeks tops; even some crazy heavy duty silicone grease.
Old Jun 13, 2008 | 02:52 PM
JZ39's Avatar
The word "clunking" perfectly describes a bad sway bar link.
I know the rear swaybar links were revised--as I had to get these, I'm not sure that the fronts were.
It is odd that it would go that fast, though.
Old Jun 13, 2008 | 03:06 PM
ShanesG's Avatar
not enough grease
broken endlink
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
tiguy99
Mar 1, 2016 11:42 AM
wuppiedog
Aug 7, 2015 11:16 AM
cyrus32
Jul 18, 2015 06:22 PM
