woW~ what are these codes??? help!
Old Jul 2, 2008 | 10:09 PM
l2eal's Avatar
My car been in a limp mode and finally got it scanned. And these are the codes that came up...I looked up the codes but stilll not quite sure what I should fix or replace....can you guys chime in maybe with a similiar problem and how it was fixed??? thanks.
P2122
P2138
P1229
P0550
P0452
P2122
P2138
P1229
Old Jul 2, 2008 | 10:18 PM
partyman66's Avatar
Most of those are Accelerator Pedal Position Sensor codes, but some of the others are other things.
Did you short something out in your car while working on an electrical component.... or was the car possibly even hit by a bolt of lighting arcing off of a nearby tree or something of that nature(that you're aware of... of course)?
I would recommend downloading the factory service manual for your car and going through some of their troubleshooting procedures for the Accelerator Pedal Position Sensor. You can get it at numerous places on the internet for free in PDF format. It's a very useful tool.
Old Jul 3, 2008 | 01:06 AM
l2eal's Avatar
no actually my car spun out and hit a tree on my read passenger side...broke my axle and smashed myquarter panel...got all the parts installed and the body work is almost done but it sitting in limp mode...warranty is gone so i didnt wanna get raped by goin to the dealer..trying to find out what it is..
Old Jul 3, 2008 | 03:05 AM
Nin's Avatar
Nin
punch those codes into google...you're almost guaranteed to get a result for all of them
i'm pretty sure they're all generic codes...manufacturer specific ones are higher numbers? can't remember
Old Jul 3, 2008 | 11:45 AM
l2eal's Avatar
anyone got any of these codes before??
Old Jul 3, 2008 | 12:19 PM
LjN_728's Avatar
P2122 - Accelerator Pedal Position Sensor
P2138 - Accelerator Pedal Position Sensor
P1229 - Sensor Power Supply
P0550 - Power Steering Pressure Sensor
P0452 - EVAP System Pressure Sensor
P2122 - Already asked
P2138 - "
P1229 - "
If fixed properly, the body shop should be able to reset the codes.
Clearing Codes
If using a scan tool, follow tool manufacturer’s instructions to clear Codes.
Using a small screwdriver to turn the diagnostic mode selector switch, located on the side of the ECM/ECU, fully clockwise. After waiting two seconds, rotate the switch to the full counterclockwise position. The diagnosis will end and memory will then be cleared.
Disconnect the car battery for at least 24 hours.
Old Jul 3, 2008 | 01:26 PM
l2eal's Avatar
i tried resetting by dis. the battery for 24 hours...still no luck it's still sitting in limp mode..im not quite sure what exactly what these code means...ok so it says that its a sensor power supply meaning what? i have to replace it?? like it lists a few sensors..are they all bad?
Old Jul 3, 2008 | 02:40 PM
LjN_728's Avatar
^ All of those issues should've been taken care by the body shop and not the consumer. You have to reset the code(s) using a OBDII reader/scan. Reading on OBD-Codes.com, you can reset a "Check Engine" light by this:
Simply disconnect your battery, turn on the headlight switch for about five to ten minutes, and re-connect the battery. This is pretty simple, but will likely result in you losing your radio presets and perhaps some other small things like that.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
KallDay86
Jan 8, 2016 12:42 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
Detailed Image
Sep 28, 2015 07:04 AM
vamarris
Sep 26, 2015 12:56 PM
