PIAA Xtreme White LED 168/194
Old Apr 28, 2004 | 09:27 PM
thehin's Avatar
Anyone have expierence with the Xtreme White *LED* wedge bulbs, how do they compare to the standard bulbs, i want LED so they dont burn out. I just wanted to know if they were the same color and intensity. Thanks
Old Apr 28, 2004 | 09:59 PM
kytran40's Avatar
Re: PIAA Xtreme White LED 168/194
i just installed the white leds into the clearance strip and xtreme white bulbs into the clear corners. in the clearance the light is white and turns light blue as it goes down the strip. with the low beams on u dont really notice any light from the strip from 25+ ft away because of the low beam brightness. the xtreme whites in the clear corners arent white enough for me up close, but they look good from a distance
Old Apr 28, 2004 | 11:25 PM
thehin's Avatar
how is the blueness compared to the bulb, is it the same for the LED, and also what do you mean by white, is it too blue for you in the clear corner?
Old Apr 28, 2004 | 11:35 PM
kytran40's Avatar
the light from the both types is pure white, in the clearance strip for some reason the light from the leds turns blue as it goes down the strip
Old Apr 28, 2004 | 11:54 PM
thehin's Avatar
is the LED the same as the regular bulb
Old Apr 29, 2004 | 12:54 AM
carmeljoy's Avatar
why did u put the led's in the clearance strips and the xtreme whites in the side markers? why not led in both?
don't start no sh*t, won't be no sh*t!
'04 g35c DG/G 5AT premium, performance, aero kit, pedals, clears, stillen lower valences
Old Apr 29, 2004 | 08:51 PM
TCFOOL's Avatar
Check it out!
http://www.imagestation.com/album/?id=4289508295
TC
[img]/w3timages/icons/tongue.gif[/img]
"There is a Very Fine Line Between "Hobby and Mental Illness"
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
Gabe83714
Oct 6, 2015 06:40 AM
Albanian122
NorthEast
Sep 28, 2015 03:03 PM
