De-Badge question
Old Jul 14, 2008 | 03:19 PM
Parker6's Avatar
De-Badge question
Im considering removing the G35 from the back trunk for a cleaner look...anyone else done this? How do you remove the badges? Also, are there any holes left when you're done...some larger emblems have rivets and glue to bond them.
Thanks!
Old Jul 14, 2008 | 03:24 PM
officerdbag's Avatar
Thanks!
no holes, its very easy! Check down at the BODY DIY section.
Old Jul 14, 2008 | 03:25 PM
Shakuya88's Avatar
No holes and you can either heat it up with a hair dryer/heat gun or just let it the sun for a bit. For actyually removing them, use fishing line. There will be a little stick left, you automotive goo gone. Let it sit on it for a bit, wipe it off, use your finger nail to get the suborn sticky off, then claybar and polish/wax and your done
Old Jul 14, 2008 | 03:47 PM
mt7rabbit's Avatar
Old Jul 14, 2008 | 03:51 PM
surfquikslver's Avatar
lots of people do this and it looks sick...i debadged my trunk completely
Old Jul 14, 2008 | 04:30 PM
SteveBlake's Avatar
I took off the G35 on mine and it makes it look so much cleaner.
Old Jul 14, 2008 | 05:33 PM
Beebo's Avatar
go smooth haha
Old Jul 14, 2008 | 05:37 PM
lekker_droom's Avatar
i took the G35 part off. I like it a lot better,
https://g35driver.com/forums/attachm...6&d=1206674128
Old Jul 14, 2008 | 05:39 PM
NyG35fL's Avatar
yea, i like it better
I replace the infiniti, G35, and symbol wit the Nissan, Skyline, 350gt
i just use a razor to grip each number/letter off, and then you have that sticky foam like, that holds it together, the best thing to use is automotive tar remover, you can find it at any auto part store.
"razor, and auto tar remover."
Old Jul 14, 2008 | 05:43 PM
Beebo's Avatar
No... No... No... not good you will **** up the paint... use fishing line
Old Jul 14, 2008 | 06:02 PM
SteveBlake's Avatar
^+1 or dental floss. NOTTTTTTTTTTTTTTTTTTTTTTTTTT a razor!
Old Jul 14, 2008 | 07:46 PM
V35 Skyline GT's Avatar
6MT Coupe
Not even your finger nail. Clearcoat scratches easy.
Negative on the Razor!! One awe shiet and you're finish is done....
Warm up the badges with a heat gun or blow drier to make removal easier.
Old Jul 14, 2008 | 07:52 PM
razor ZOMG! Thats like playing russian roulette
Old Jul 14, 2008 | 07:53 PM
Ghayes23's Avatar
Dental floss or fishing line is the only way to go.
Dude, here. This is the best link for a Debadge.. it has a video for **** sake
https://g35driver.com/forums/body-interior-exterior-lighting-diy/217086-diy-emblem-debadging-w-pics-video.html
